Barroll
Joined: Fri Jan 15, 2010 10:19 am Posts: 932 Location: Georgia
 Oil leak question
My new gtr developed a oil leak at the fitting where the oil line goes from the oil cooler to the oil filter area. I am going to replace the pos hose clamps that come on the motor with the good screw ones but I also need to fix the fitting. Question is what is typically used on fittings like this? Can Teflon tape be used or is there something special to use around oil ports?
_________________ 1848 Prodigy 35 GTR
Wed Dec 18, 2013 7:43 pm |
dirtybird29+
Joined: Mon Feb 15, 2010 8:03 pm Posts: 393 Location: South Carolina
 Re: Oil leak question
Mine did the same thing after 11 hrs on it. I took the hose loose and tighten fitting one turn and haven't had a problem since.
_________________ 1854 GTB Extreme 35GTR
Wed Dec 18, 2013 7:58 pm |
doubleBanded
Joined: Sun Feb 03, 2013 1:26 pm Posts: 3084 Location: Down South
Mine is doin the same thing. At first I thought is was the bottom of the filter but think it's coming from hose
_________________ 1852 Dfou custom 35gtr
Wed Dec 18, 2013 8:03 pm |
missile
Joined: Mon Jun 18, 2012 7:33 pm Posts: 681 Location: DeKalb, Texas between the rivers
 Re: Stock 35 Vanguard camshaft specs.
Tighten up the 90°
_________________ Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's Boat Name: The Gar Barge Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Wed Dec 18, 2013 8:48 pm |
diddyduck
Joined: Mon Sep 02, 2013 10:24 pm Posts: 2624 Location: ponchatoula, la
had the same issue...take the fitting off..plumbers tape..put it back no issues since
Wed Dec 18, 2013 8:53 pm |
Barroll
Thu Dec 19, 2013 8:28 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
those 90 degree fittings are not tight on the new motors for some reason, all u have to do is tighten it and ur done!
Thu Dec 19, 2013 8:30 am |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
I just tightened mine and it worked good. If you want to start over you can use teflon tape. It's good for up to 500 deg.
Thu Dec 19, 2013 8:36 am |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Thu Dec 19, 2013 8:38 am |
msm8281
I searched "frequently asked qustions of teflon tape" and that's what it said.
Thu Dec 19, 2013 8:41 am |
MNGunner
Thu Dec 19, 2013 8:44 am |
msm8281
Another website said 450-550f. So it exceeds the oil temp by double so it should have no problem for this application.
Thu Dec 19, 2013 8:49 am |
cb5331
Fine for the temps, but will it stand up to oil/fuel? Never looked myself, but been told it won't and its pretty much useless for oil and fuel fittings.
Thu Dec 19, 2013 9:19 am |
pokey79
I know from the factory they put some red stuff like pipe dope on them
Thu Dec 19, 2013 9:20 am |
duckkillah
Joined: Fri Jul 17, 2009 6:08 am Posts: 100 Location: Upper East TX
They make Teflon tape for use in gas pipe applications that should work. I believe its pink instead of white.
_________________ Brother's 18x54 GTR with a little somethin'
Thu Dec 19, 2013 9:26 am |
pokey79
that would explain the red pinkish stuff they use from the factory
Thu Dec 19, 2013 10:19 am |
diddyduck
used the regular old white plumb tape and its been about 100 hrs..no issues
Thu Dec 19, 2013 10:35 am |
Charlie-echo
Joined: Sat Aug 11, 2012 11:19 am Posts: 63 Location: Covington, LA
Glad I found this topic last week, mine started leaking this morning on the way back to the launch. 35 GTR with about 35 hours on it.
_________________ 2013 1854 Gator-Tail Extreme center console w 35 GTR
Mon Dec 30, 2013 2:38 pm |
Barroll
Yea. I just tightened mine down one turn and put hose clamps on the hose instead of quick connects. I have put 15 hrs on it since with not a drop leaking. GT must have ordered motors built on a friday...lol
Mon Dec 30, 2013 5:10 pm |
