It is currently Sat Jun 21, 2025 11:24 am
Reply to topic  [ 8 posts ]
 Can a recessed plug cause cylinder to run lean?
Post Can a recessed plug cause cylinder to run lean?
I've been chasing an issue with the #2 cylinder running lean, pulled the head tonight and was surprised to see the plug about 1/2" from being fully seated. Thought at first that I had set the plug in and forgot to torque it down, but once I looked at the threads it's pretty obvious that they are so jacked up the plug couldn't have ever been fully seated.
Doesn't make sense that this would cause the cylinder to run lean, I'd think if anything it would run rich, but I feel dumber than a box of rocks sometimes.
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Thu Dec 19, 2013 2:52 am
Post Re: Can a recessed plug cause cylinder to run lean?
if the plug was not sealing you could have been sucking in air through the treads on the intake stoke....So that could cause you to run lean just like a leak on the intake.
Thu Dec 19, 2013 9:03 am
^BINGO!!
Thu Dec 19, 2013 9:13 am
Well good, maybe I can finally solve that problem. Prolly gonna get it helicoiled.
Thu Dec 19, 2013 10:12 am
Thu Dec 19, 2013 10:13 am
You may have not torqued it down. It could've wallowed the threads out. A guy at work had it happen and it shot his plug out.
Sent from my iPad using
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Thu Dec 19, 2013 4:06 pm
Thu Dec 19, 2013 5:20 pm
Thu Dec 19, 2013 5:38 pm
Users browsing this forum: Google [Bot] and 197 guests
