It is currently Wed Dec 17, 2025 6:08 am
Reply to topic  [ 13 posts ]
 Honda GX660 motor problems
Post Honda GX660 motor problems
My motor will start and run fine but after a while of running it, it will run out of fuel and die. I can keep it running by continually squeezing the bulb on the fuel line. I just replaced the fuel filter and spark plugs and that did not help. Has anyone had this problem and if so how did you fix it? Thanks in advance for all help!
Wed Dec 18, 2013 8:41 pm
Post Re: Honda GX660 motor problems
Yup remove the fuel cutoff solenoid and clip the needle off
Ethanol and water causes the solenoid to stick and bam you got no fuel
Holler back you got any querstions
Wed Dec 18, 2013 9:16 pm
Is there a way to reset the solenoid? And thanks for the help
Wed Dec 18, 2013 9:34 pm
Hold up on cutting anything just yet, Sounds like you have air getting into the fuel system some where. Start at the tank check your pick up tube and make sure there is no restictions also check to make sure the pick up tube isn't loose. Quick connects can be the devil, also old fuel line tend to delaminate causing inline fuel blockages. Check the primer ball for cracks and also make sure the check valve are working properly.
Wed Dec 18, 2013 9:57 pm
Like this? :lol:
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Wed Dec 18, 2013 10:07 pm
:lol:
Nice!
Thu Dec 19, 2013 7:52 am
The guy I bought my bass boat from had put a mercury replacement line which is what the pic is. I had trouble every once in a while with getting on step. If I eased into it I wouldn't have a problem. I fished a tournament on Toledo Bend and ran some 2.5' waves to the Texas side and back. Next thing you know all I could do is putt putt. Couldn't get on step. Went home drained the tank, pulled the filters and the inline filter was plug with plastic. When I squeezed the bulb to drain the tank chunks were coming out. I went back with all blue ethanol resistant line and blue Marpac bulb. Never had a problem since.
Thu Dec 19, 2013 9:43 am
Ok so when I squeeze the bulb gas will go into filter and then it will drain all back out. So I'm gonna get a new bulb and try that. I've checked all fuel line and everything looks good.
Thu Dec 19, 2013 12:26 pm
Get the blue Marpac. It doesn't get hard like the cheap ones. It also has a double stainless ball check valve.
Thu Dec 19, 2013 3:10 pm
Alright will do! And thanks again to all you guys for the help!
Thu Dec 19, 2013 3:14 pm
Thu Dec 19, 2013 5:54 pm
Make any head way on this?
Fri Dec 20, 2013 10:35 pm
Yes! It was the bulb. Runs like a champ now! Thank you all for the help!!! Much appreciated!
Sun Dec 22, 2013 7:56 am
