It is currently Wed Jun 25, 2025 3:17 pm
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 Bought a Boat with pods.
Post Bought a Boat with pods.
I picked up a 16x52 aluminum haul and trailer, in pretty good condition. And exactly the layout I was looking for.
The boat has pods welded on. The owner had a long tail on the boat.
I KNOW pods are not the greatest thing for a mud motor.
I put my 2013 36 pro drive on the boat.
By myself, I'm only running about 25.8 mph. I'm just wanting y'all opinions on if I should cut the pods off or not.
They are not even with the bottom on the boat, I'm not sure if I should keep them on, or take them off.
Any ideas/advise would be great. I can't sell boat an get another, after this duck season, I will have a boat build for my motor. I'm just looking for any info.
Thanks again!
Wed Dec 18, 2013 4:46 pm
Post Re: Bought a Boat with pods.
Cutem off also check your transom angle.
35 GTR chasin a BBC 1848
Wed Dec 18, 2013 5:43 pm
Wed Dec 18, 2013 5:51 pm
No clue bud, maybe on of the prodrive guys will chime in.
Wed Dec 18, 2013 5:54 pm
Wed Dec 18, 2013 5:57 pm
Every day I'm paddlin'
Wed Dec 18, 2013 6:05 pm
I believe the transom angle for prod rive is 12°
Sent from my SCH-I545 using Tapatalk
Wed Dec 18, 2013 6:19 pm
Wed Dec 18, 2013 6:25 pm
I know everyone will tell you to take them off but I would leave them. Speed is not bad for a stock motor. I know a few people who have added them and they have helped. If you do take them off post your speeds and a review of the difference without them. One buddy had some added to his alweld and it helped the squatting and the hopping when riding solo.
Wed Dec 18, 2013 6:28 pm
Wed Dec 18, 2013 6:32 pm
Wed Dec 18, 2013 6:53 pm
I plan on cutting the pods off tomorrow. And before I boxed in the bottom on the transom, I also planned to put either 2 trim tabs in the back, or a full piece of alum. Plate across the bottom as a full trim tab.
Any preference between the both?
Wed Dec 18, 2013 7:01 pm
Full width but that can be done by making tge bittom plate of your box 2 long
Wed Dec 18, 2013 7:05 pm
Wed Dec 18, 2013 7:12 pm
For a prodrive you need a 15 degree transom angle.
Not sure I would cut those off.
Your speeds are good for that package.
I had a 16X48 with cut back transom and had to add pods to keep boat from squatting and backwashing....
I would not recommend pods in MOST circumstances with a surface drive, but yours seems to be working and I would not mess with it. They sit high enough that they are probably not effecting performance on top end and only helping you on take off and running slow...
Your biggest problem is the boat in general and if you are replacing it after this duck season, I would run it like you got it till then....
Wed Dec 18, 2013 9:43 pm
Mines got pods but if i had reverse they would come off
Wed Dec 18, 2013 10:24 pm
Thu Dec 19, 2013 7:25 am
15*
As far as the pods, i would cut them off. I also have a taper transom. I boxed mine in as well because i couldn't stop the damn thing from bouncing at high speeds. When I boxed it in, I left a 1.5" tab all the way across. Now it runs great and don't have the slightest issue with reverse.
Thu Dec 19, 2013 11:37 am
Thu Dec 19, 2013 12:16 pm
Thu Dec 19, 2013 1:21 pm
Thu Dec 19, 2013 1:25 pm
Thu Dec 19, 2013 3:38 pm
Took plasma cutter and cut it out.
Cut out old plug pipe and welded another piece of 3/16 to bottom. Used a square to insure it welded straight to bottom and didn't hook.
Thu Dec 19, 2013 3:42 pm
Welded in new plug hole. painted it back. I just had to sand off the gator glide at that point to do all the welding. painted it back normal with green cuz I didn't have anymore GG. Now I can fine tune it depending on the load. Doesn't effect it one bit in reverse.
Thu Dec 19, 2013 3:44 pm
Forgot to add, I welded the splice piece top and bottom. Then I came back and used a flap disc to sand the bottom welds smooth with teh bottom so it wouldn't act like a hook. So if you get inder my hull, you cant tell where it was welded, and now its painted.
Thu Dec 19, 2013 3:46 pm
Thu Dec 19, 2013 9:05 pm
Fri Dec 20, 2013 9:46 am
Fri Dec 20, 2013 9:51 am
Fri Dec 20, 2013 9:56 am
Fri Dec 20, 2013 10:03 am
Fri Dec 20, 2013 10:16 am
Gas tank is in the middle of the boat, I haven't moved it forward yet.
Battery is in the back. Even with another person up from weighing 180lbs it still hops a little. Nothing major.
But if the person is 130, it hops a lot.
I checked out the bottom of the haul, it doesn't appear to be hooked.
But I do know you can't always see it.
Fri Dec 20, 2013 10:20 am
Fri Dec 20, 2013 10:22 am
Fri Dec 20, 2013 10:27 am
How is the boat running now without the pods? What are your speeds now, and do you like it better with them off or on?
Thu Jan 02, 2014 7:04 pm
Thu Jan 02, 2014 7:15 pm
One thing i am noticing is that the boat doesnt ride flat. (it didnt ride flat even with the pods)
And it feels like that is also holding back my speed a little.
and i noticed that my motor feels like its getting a better bite. May have been that the pods were somehow disturbing the water to the prop????
I need to figure out how i can make it run flat to help me a little.
Even with all the weight in the front, 9 gal gas tank, battery, and 1 person, it still doesnt put the front end down.
i havent had a chance to ride it solo yet, but i will has soon as possible.
I read lots of things on here about trim tabs getting hung up on lots of stuff with motors with reverse. So im looking for something else to help.
Anyone?
Mon Jan 13, 2014 8:31 am
Mon Jan 13, 2014 10:11 am
I guess I will try the trim tabs! Maybe it will work for me! I will be ordering my boat within the next few months. So I'm just trying to make this work for the time being. I'll be going with a 17x52, so hopefully that's all the boat I need. I'm sure I'll find something to get another boat built in the future! :D
Mon Jan 13, 2014 11:27 am
Mon Jan 13, 2014 12:41 pm
Users browsing this forum: No registered users and 128 guests
