It is currently Wed Dec 17, 2025 7:01 pm
[ 9 posts ] |
Prodrive problem. Got me Stumped
swamprooter
I have a PD 36 that when I put it in gear and under load, it will violently jerk the tiller and cut off. It will crank and run like a bat out hell in neutral or prop in gear out of water. But soon as it has to push boat, motor sta rts shakin and it cuts off. What In world is going on? Help. Thanks
| Tue Dec 24, 2013 1:03 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: Prodrive problem. Got me Stumped
Sounds like you have a bad bearing or bearings in the lower unit. Can you spin the prop by hand?
| Tue Dec 24, 2013 1:15 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
missing on one cylinder!
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
| Tue Dec 24, 2013 1:36 pm |
JIMMY W
bad bearing and it would do it out of the water also!
| Tue Dec 24, 2013 1:37 pm |
swamprooter
I can spin prop with my hand. I can put in gear and putt around forward but as soon as I give it some gas it will jerk and go dead
| Tue Dec 24, 2013 1:55 pm |
bayouboy
| Tue Dec 24, 2013 3:57 pm |
swamprooter
So I can put it in gear out of water and it will run 4000 rpm with no evidence of a prib. Would that still be a bearing? How hard is it to fix a bearing. I barely know difference between a friut basket and a head gasket but aint scared to learn
| Tue Dec 24, 2013 4:21 pm |
bayouboy
I find the easiest way to check a dead cylinder is to fire it up and check each exhaust port to see which one gets hot. The cold one is dead. Or you can pull the plug wires one at a time.
| Tue Dec 24, 2013 6:39 pm |
swamprooter
Thankz guys! Found the problem. Embarrassed to say it was a bad plug. Replaced the dirtyplug and cylinder hit right up
| Wed Dec 25, 2013 3:37 pm |
[ 9 posts ] |
