It is currently Thu Jun 19, 2025 5:42 pm
[ 5 posts ] |
MBFT
 Mudbuddy clutch help
Got towed in tonight due to clutch problems on my 4500 BD. It would go into gear but as soon as u give it gas it jumps back in neutral. It got to the point that it won't even go in gear. My question is does it sound like the clutch circuit breaker went out or the clutch itself? Motor has about 125 hrs on it. Gonna give it a look in the morning and any advice would be appreciated! Thanks
Wed Jan 01, 2014 7:12 pm |
SCmudder7071
 Re: Mudbuddy clutch help
Check wire leading to clutch. Could have worn through.
_________________ 1754 Extreme/LAProp Stage 2 GTR
Wed Jan 01, 2014 7:27 pm |
duckshot
Had the same problem, my switch was shot. Gave it throttle and the vibration would cause the switch to drop out.
Wed Jan 01, 2014 8:43 pm |
barnes_53
The quickest way to eliminate the switch as an issue is to open the football and pull the single red wire off and connect it to the brown wire (forward position). This will enable the clutch directly and you can crank the engine wired this way. However, it bypasses the neutral position.
If it still behaves like you described it not the switch.
Wed Jan 01, 2014 8:57 pm |
MBFT
Thanks for the help
Thu Jan 02, 2014 5:28 am |
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 128 guests |
