It is currently Thu Sep 11, 2025 8:08 am
Reply to topic  [ 84 posts ]  Go to page 1, 2, 3  Next
 Shotgun Factory Camo Mod
Post Shotgun Factory Camo Mod
I didn't like how bright my Benelli's MAX 4 camo was considering my hunting locations, flooded timber, cypress swamps, etc...I wanted a more grey look so, went to experimenting and found out how to dye the camo for a different appearance. It's super easy and cheap. I used Fiebing's leather dye. Just apply the dye to the part, give it about 10 seconds and wipe it off, then buff with a rag. Since I wanted a grey look, I chose the black dye, if you wanted to just darken it and keep the same, you could use a dark brown. It doesn't not come off after a couple of minutes, I've tried soap and water, I even rubbed a spot this morning with a white cloth and alcohol and it's fine. I'm super please with it and thought I would share. I assume this trick will work on any dipped camo pattern.
This is a before close up.
This is an after close up.
Here, the barrel is done but not the action and stock.
Forearm before
Forearm after
With the dye on the action.
Barrel before
Barrel after
Final product
Fri Jan 10, 2014 5:41 am
Post Re: Shotgun Factory Camo Mod
Will, that's awesome! I shoot the same gun and don't like the color. I'll be ordering some black today. Thank you for sharing!
http://www.gatorglide.com/
gatorheads@comcast.net
Fri Jan 10, 2014 5:53 am
Here's the original test subject with brown, I just wanted a grey look.
Fri Jan 10, 2014 6:24 am
That looks awesome!!
Sent from my iPhone using Smoke Signals
1646 Gatortail dragging a stage 1 GTR
Fri Jan 10, 2014 6:50 am
Looks good. Does it make it shine at all in the sun?
Fri Jan 10, 2014 6:57 am
Awesome! I'll be doing that with mine too.
Fri Jan 10, 2014 6:59 am
Fri Jan 10, 2014 7:00 am
This is the brand dye I used... http://www.amazon.com/Fiebings-Leather- ... s=fiebings
Fri Jan 10, 2014 7:03 am
Cool thanks.
I'm gonna try that on my M2 with APG pattern when I get home!
Sent from my DROID RAZR using Tapatalk 4 Beta
Stage 2 Mini 23 chasing a 1642 Prodigy
Fri Jan 10, 2014 7:25 am
Very cool! Turned out awesome!
Fri Jan 10, 2014 8:11 am
Wonder how a Max4 pattern would turn out with green on it? Down south Max 4 sticks out badly.
Copperhead 12Hp SD on 1442 Alweld
Fri Jan 10, 2014 8:14 am
Fri Jan 10, 2014 8:23 am
That looks really good Will. I hate how bright the max 4 is on mine. Might have to try that.
cmiller, are you gonna try the green?
Fri Jan 10, 2014 10:10 am
I am very impressed with it,Great job and info Will.
Fri Jan 10, 2014 11:34 am
Nice job will!
Fri Jan 10, 2014 11:52 am
Now that is some useful information
Fri Jan 10, 2014 12:03 pm
It looks even better now, the brown leaves are standing out. Lots of different shades.
Fri Jan 10, 2014 12:06 pm
You ain't half bad for a white boy will
16x42 Charles Leonard ... Sold
18x46 Gator Tail w/ 35 gtr stage 1 by hoyt
Fri Jan 10, 2014 12:41 pm
Sometimes I am worth a shit.. :lol:
Fri Jan 10, 2014 1:10 pm
You should see it in person though. Cant get the pictures to do it justice.
Fri Jan 10, 2014 1:16 pm
Will where did you get your after market parts for your Chamber pull and your push button on your gun?
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Fri Jan 10, 2014 1:31 pm
Fri Jan 10, 2014 1:32 pm
Fri Jan 10, 2014 2:19 pm
For the record, Bug started this brainstorm...
Fri Jan 10, 2014 2:23 pm
Fri Jan 10, 2014 2:35 pm
Fri Jan 10, 2014 2:41 pm
Fri Jan 10, 2014 2:51 pm
Fri Jan 10, 2014 3:09 pm
I know he got real quiet on the football thread
Fri Jan 10, 2014 3:14 pm
Fri Jan 10, 2014 3:23 pm
Can't find that shit anywhere locally...guess I'm not doing mine tonight.
Fri Jan 10, 2014 4:03 pm
Fri Jan 10, 2014 4:10 pm
The Leather Pouch in Lafayette has it for those around here.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Fri Jan 10, 2014 4:56 pm
If you do this, get the darkest color. Do a small section to where its on about 10 seconds then wipe it off, you can do more layers to make it darker if you want. Little at a time. I'm going to put it to the field test tomorrow and will report back.
Fri Jan 10, 2014 5:50 pm
Here's our test dummy after 3 coats. The first was in medium brown (not recommended :oops: ) and two coats of dark brown to get rid of the orange hue it had from 1st round which has caused a little luster. I'm sure a scotch-brite will cure that though. These pictures were taken very shortly after coating it and there seems to be some lightening after curing (over night). Also an alcohol soaked rag will remove most of the color when it's fresh but won't cut it worth a damn later. Fiebing's color chart is DEAD ON THE MONEY as to the tint so check it first BEFORE you smear something on it that's worse than cornbread yellow :shock:
PRODRIVE 1860 CC
"Let the good times roll"
Fri Jan 10, 2014 7:47 pm
Thanks again guys, did you wipe the gun down with alcohol prior to applying the dye? Bug, a good wipe with denatured alcohol will help flatten out the sheen some.
Fri Jan 10, 2014 9:17 pm
Nice job will, great post.
Sat Jan 11, 2014 12:32 am
Thanks will.....i might need to do mine like that.
i think my gun is soo fukkin bright,its flaring birds clean out of lafourche parish!
i aint killin shit and nobody around me is either :oops:
maybe this da ticket lol.
Sat Jan 11, 2014 3:46 am
Sat Jan 11, 2014 3:59 am
