It is currently Thu Dec 25, 2025 7:39 am
Reply to topic  [ 8 posts ]
 Converting short transom to talll on pd
Post Converting short transom to talll on pd
Any of y'all ever done this? About to have a tall transom hull built and gonna have to order the parts from pd and convert my motor.. Didn't know if it was a pain in the ass or not
Mon Jan 13, 2014 3:11 pm
Post Re: Converting short transom to talll on pd
Few hundred in parts and a big ass welder is all you need. Its pretty easy.
Mon Jan 13, 2014 3:22 pm
You might PM gator22. I know he had a lot of transom work done on his boat for a SD. Hope this helps
Mon Jan 13, 2014 3:36 pm
cool well that wonlt be a problem, got the few hundred and a big ass welder.
Mon Jan 13, 2014 8:30 pm
I thought someone did this a while back. Contacted PD and had to get a different mid section and such.
Wed Jan 15, 2014 10:43 am
Dont need a new tower. Just a spacer welded on the old one, a new teflon bushing, a spacer for the inside, and longer bolts for the lu.
Wed Jan 15, 2014 10:59 am
Just did mine, Took maybe two hours. While you have it apart check how much play the pin in the tower block has in it. Basically the pin that goes through the tower, trim arms, and mounting bracket. I am pulling mine back apart to have it machined for a bushing. I want to say the parts were less that 200 but not exactly sure.
1648 gd hull flying in front of a stage 3 with fpr
Fri Jan 31, 2014 6:49 pm
Mon Feb 03, 2014 5:08 pm
