It is currently Fri Mar 27, 2026 4:01 pm
[ 6 posts ] |
Will I need gear change after motor work?
tlsmith22
Joined: Sat Jan 08, 2011 8:01 pm Posts: 175 Location: North Alabama
Have a 2012 45 that I am gettn headwork(port and polish, .015 decking) done right now and also adding a dual carb setup. The reason I am asking if I will need to change gears is I also am having to change the crankcase cover so I am gonna have the outdrive off. I am running a 2054 custom with a 32 in outdrive and a hammer prop with a single mikuni carb. Right now I am turning 4400 rpms solo and 4300 loaded down. I am running 38/48 gears. Do u think I will need to change to a 46 gear to keep the rpms down? I dont wanna run it towards the rev limiter all the time. Thanks guys
| Sun Feb 16, 2014 9:36 am |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 Re: Will I need gear change after motor work?
On that big of a boat I'd stay with those gears.
| Sun Feb 16, 2014 9:53 am |
AKA Freshwaterkilla
X2 or go to a 50 t on the bottom that is a big boat
Sent from my iPhone using
| Sun Feb 16, 2014 2:28 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
38/48
| Sun Feb 16, 2014 10:29 pm |
The Hairy Coot
Joined: Wed Aug 28, 2013 10:40 pm Posts: 717 Location: Louisiana
What factors will be affecting weight? What will be your estimated avg weight?
| Sun Feb 16, 2014 11:22 pm |
50fps
You will want to keep the rpms up with the dual carb setup to see any benefit. 38/48 1.26-1 ratio is light to me.
| Mon Feb 17, 2014 7:27 am |
[ 6 posts ] |
