It is currently Mon Apr 13, 2026 6:21 am
Reply to topic  [ 7 posts ]
 Bunk Boards
Post Bunk Boards
I noticed this weekend that I have a broken bunk board. Has anyone ever tried the synthetic deck boards? If not that I am considering some treated boards with polyurethane. I am done with carpet. I do want them the boat to slide a little better. FYI my boards sit 1 1/2 on top not 3 1/2 so im not thinking I can use the slick poly things on the boards. Id like to hear your thoughts.
The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides
It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown
Greater love has no other than this that he lay down his life for his friends. John 15:13
Mon Dec 21, 2009 8:16 am
Post Re: Bunk Boards
For about the same cost as the deck boards, try ultimate bunk boards. They are a HDPE 2X4 or 2X6. Have been using them for 2 years with good luck. http://www.ultimatebunkboards.com/
Mag10
Mon Dec 21, 2009 9:38 am
1648 old style bass tracker with a...........................
50 Nissian on a 17' Lakesport.
Mon Dec 21, 2009 10:01 am
I would go with the 2x6 over the deck boards for better strength. Depending on cross brace spacing deck boards may sag. I have 4 treated 2x6s laying flat. At 9' that would cost over 300.00 for those fancy bunk boards. The synthetic type deck boards are not stiff enough unless you have multiple cross braces on your trailer.
18x48 Charles Leonard / 36PD
Mon Dec 21, 2009 11:22 am
I used a 1 1/2" X 1 1/2" X 1/8" angle under the bunks. I used a spade bit to counterbore the heads of the carriage bolts and washers below the surface. The high density polyethelene is pretty rugged, even in below zero temps.
Mag10
Mon Dec 21, 2009 12:24 pm
My Magic Tilt came with a plastic cover on the 2x4 bunks instead of carpet. This boat slides on and off better than my last boat on carpet covered bunks.
Mon Dec 21, 2009 5:52 pm
Put you some cypress on there and be done.
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Thu Dec 24, 2009 11:18 am
