It is currently Sun Dec 21, 2025 5:21 am
Reply to topic  [ 17 posts ]
 Changing from a gd 3 blade to a ?
Post Changing from a gd 3 blade to a ?
Put heads cam exhaust on my 23 and i can turn my brand new 3 blade 4100 looking to change to a big 2 blade what prop size can u turn as good with a 2 blade
1440 xpress 23 gdsd... Sold
1644 gd 35 gtr
Sun Apr 06, 2014 11:14 am
Post Re: Changing from a gd 3 blade to a ?
Sun Apr 06, 2014 11:17 am
Thats what it originally had i got more out of the 3 blade stock than the two blade
1644 gd 35 gtr
Sun Apr 06, 2014 11:27 am
40HP Gatortail
Sun Apr 06, 2014 12:57 pm
Well i didnt no if i would be able to turn a big blade as good or not
1644 gd 35 gtr
Sun Apr 06, 2014 2:14 pm
40HP Gatortail
Sun Apr 06, 2014 2:32 pm
Mine will run 29 empty but it lifts to bad u have to hold it in the water
1644 gd 35 gtr
Sun Apr 06, 2014 3:10 pm
try the big blade love it you got moddes it will drop rpms a lil but shouldn't lose speed and your take off should be better
Kleibert custom 18/50 push by a 35 gdsd with a lil pixie dust
Tue Apr 08, 2014 8:30 pm
How are y'all going to put a hex big blade on a threaded gd shaft?
Sent from my beeper
Tue Apr 08, 2014 8:34 pm
40HP Gatortail
Tue Apr 08, 2014 8:38 pm
tiger does not make props for mudbuddy they make a thread for godevil to
Tue Apr 08, 2014 8:57 pm
the godevil 3 blade is bad about lifting at high rpms at 4600 you can not with all strength hold it in the water and run for longer than 2 minutes but only have that prom with the gd 3 blade and played with trim tabs 20 times the prop is just not designed for high rpm use
Tue Apr 08, 2014 9:00 pm
With a lathe and mill anything is possible
1644 gd 35 gtr
Yea and the three blade i had to bend the shit out of my skeg when i put it on it pulled like a sob
1644 gd 35 gtr
Tue Apr 08, 2014 9:02 pm
you coco designed it for stock motor to turn 3900 or less rpms not a modded motor it doesn't have enough clearance between the blades for a blanced motor to hold down if you try the tiger let me know about to build a swamp boat with a 23 gdsd with heads carb exhaust and cam on a 16/36 or 38 and want to use the tiger just because how well it does with eating grass been places longtails dream with that prop just need a lil motor and little boat to get between trees
Tue Apr 08, 2014 10:23 pm
I ran my 3 blade gd prop at those rpms for miles and never had it lift unless it was wore out
Sent from my iPhone using
Wed Apr 09, 2014 8:26 am
Work on your trim tabs and you will be ok. Many people run modded go devils with three blades. You just need to adjust yor tabs and trim it correctly.
40HP Gatortail
Wed Apr 09, 2014 8:48 am
