It is currently Sun Jul 06, 2025 11:40 am
Reply to topic  [ 67 posts ]  Go to page 1, 2  Next
 GTR lower unit grease not coming out
Post GTR lower unit grease not coming out
I searched and couldn't find anything, so I figured I'd ask. I took out the screw and pumped a couple pumps and the old grease starting coming out. After a couple more pumps, no grease came out. Gave it another 10 or so pumps and still nothing. I waited a couple minutes and pumped another 5 or so and nothing came out. Its not coming out any of the seals, which is a good thing, but I don't understand how it could get clogged. And yes I made sure the grease gun still had grease in it. Any thoughts?
Sat Apr 12, 2014 6:25 pm
Post Re: GTR lower unit grease not coming out
Keep pumping till your arm hurts. It'll come out eventually:lol:
Sat Apr 12, 2014 6:28 pm
When I put grease in my Lu I remove screw and then start motor put in gear and pump grease till it comes out just remember the prop is unforgeven
Sat Apr 12, 2014 6:30 pm
I just don't get why it was coming out and then it stopped. I dont want to mess up anything else.
Sat Apr 12, 2014 6:33 pm
Mine does the same thing sometimes...just a pocket of air...as long as the screw is out it shouldnt blow a seal. Keep pumping
Sent from an Apple Tree..
Sat Apr 12, 2014 6:39 pm
^^^^^ This ^^^^ Keep pumping, just an air pocket.
Sat Apr 12, 2014 6:42 pm
I've pumped about ten times with nothing coming out.
17x54 Extreme W/ GTR-35L Stage 1
Sat Apr 12, 2014 7:14 pm
are you using a cheap grease gun? I went thru about 5 of those things till I switched to air one
Sat Apr 12, 2014 7:31 pm
Turn your prop 4 or 5 revolutions... it will free it up and start coming out.
you drink the kool aid, id rather drink the whiskey and raise hell!!!!
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Sat Apr 12, 2014 7:53 pm
I keep hearing about seals, is it possible with a GT to blow the seals? I've topped mine off many times without removing the screw. My grease has never been off color.
Sat Apr 12, 2014 8:29 pm
I've put about 2 whole cans of grease in there. The old grease is coming out, just very slowly. Turning the prop helped, but it is still very slow. Guess ill get a third can...
Sat Apr 12, 2014 8:39 pm
Quit playing with that baby gun and get a fullsize one. Them lil minis hardly have any grease in those tubes.
Sat Apr 12, 2014 8:41 pm
you will like this - it kicks @ss
http://www.amazon.com/Lincoln-1162-Air- ... B0019COQ6C
Sat Apr 12, 2014 9:28 pm
Yea I might have to invest in one of those.
Sat Apr 12, 2014 9:30 pm
I bought one 3 years ago - cannot live with out it now.
Sat Apr 12, 2014 9:35 pm
I been contemplating getting one for a few years..
Sat Apr 12, 2014 9:57 pm
Sat Apr 12, 2014 10:35 pm
I have a cordless one its pretty bad ass
Sent from my iPhone using
Sat Apr 12, 2014 10:47 pm
I use a Lincoln as well, but I have battery powered instead of air. Works great IMO..
You can't fix stupid
Sun Apr 13, 2014 8:51 am
This thread made me laugh.
Sun Apr 13, 2014 8:52 am
^^ cheap entertainment is hard to find :D
Sun Apr 13, 2014 8:58 am
Sun Apr 13, 2014 9:20 am
I'm down to my last tube of grease. I have put 5 in there. It's still barely coming out and its a dark greyish in color so I know they still have old grease in there. I never had this problem with my other motor.
Sun Apr 13, 2014 2:20 pm
I'm afraid to say that i think there is a possibility you filled up the belt housing.
Sun Apr 13, 2014 2:30 pm
You are def putting it in belt housing, that will be fun to clean. :lol:
Sun Apr 13, 2014 2:32 pm
Fuck. Is there any easy way to clean it out? And I'm going to guess no...
Sun Apr 13, 2014 2:36 pm
Guess ill be heading to gatortail tomorrow. Is this a common thing?
Sun Apr 13, 2014 2:44 pm
And this is why i purge my LU every time i use it.
I honestly don't know. I'll never have this issue because I'm a maintenance freak.
Sun Apr 13, 2014 2:58 pm
No its not common. How many hours you have on that thing? How often do you grease it?
Sun Apr 13, 2014 2:59 pm
The seals fail, some sooner than others. If you shine a flashlight down your belthousing u will see the pile of grease at the bottom i am guessing. Pull the lower unit and replace seal at a minimum, if i recall its like 15 bucks. Be sure to inspect bearing, race etc while u got it apart. Alot will say replace everything while u got the bitch apart, up to u. Belt housing not hard to clean out just messy.
1944 skiff with 35 GTR
Sun Apr 13, 2014 3:16 pm
I just bought it 2 fridays ago from someone. The motor has 12 hours on it.
Sun Apr 13, 2014 3:27 pm
I bet it's never been maintenanced. ... prolly original oil....what year is it?
Sun Apr 13, 2014 3:43 pm
Must been bad seal from get go with if only 12 hrs on it
Sun Apr 13, 2014 3:53 pm
Sun Apr 13, 2014 3:58 pm
Sun Apr 13, 2014 4:07 pm
For his sake I hope 3 ounce..
Sun Apr 13, 2014 4:11 pm
12 hrs....Is that the original tach?
Sun Apr 13, 2014 4:18 pm
Everything was a 2012 on the motor, but the motor had some sort of defect and he got a new one which is why it only has 12 hours on it. The frame and the rest stayed the same. But I talked to him and he said he purged the grease every 15 hours. And no, I'm talking about 5 14oz tubes of grease. That's why I was so skeptical to keep pumping after 2. This is the first time I have purged the grease on a 35 hp, I have only done it on my 25hp, so I figured it might take more... Guess I was wrong. Its definitely in the housing because i see it on the belt because I was turning the prop to help the grease come out of the screw hole. So let's just say there isn't much friction on the belt right now.
Sun Apr 13, 2014 5:11 pm
that's almost 5 pounds of grease :shock: :o :shock:
Sun Apr 13, 2014 6:00 pm
Users browsing this forum: No registered users and 50 guests
