It is currently Thu Dec 18, 2025 4:08 am
Reply to topic  [ 53 posts ]  Go to page 1, 2  Next
 Broke Fan-Flywheel
Post Broke Fan-Flywheel
Anyone seen this happen before? Was just running down the bayou when all hell broke loose. One piece went flying through the plastic cover up about 30' in the air. As soon as it happened I shut the engine off. Any ideas on what caused this or is it that the plastic fan gets so hot that over time it developed a hairline crack and finally went? Does it look like I need anything else beside the fan? I did away with the studs and rotating screen and just used the outer screen.
Also anyone in the SETX area know what they are looking at and wouldn't mind checking it out let me know. Thanks
1754GT 35GTR
Thu May 22, 2014 4:32 pm
Post Re: Broke Fan-Flywheel
Happened to me, reason it did that is because you left the ring and studs out and if caused the fan to flex and break. I learned the hard way too.
Thu May 22, 2014 4:34 pm
Check your coils make sure nothing is busted up underneath the cover. Replace fan.
- Mark Twain
Thu May 22, 2014 4:35 pm
Do not run it like that also.... It acts as a balance when spinning.. out of balance is a bad thing with the motors!!
Thu May 22, 2014 4:37 pm
1754GT 35GTR
Thu May 22, 2014 4:47 pm
I dont know why, but for some reason those broken bolts always come out with little to no probems. I start by removing the flywheel, then drill the broken part out, and when I feel the drill bit start to bite I push a little harder and 99% of the time they spin out the other side of the hole........Just dont push so hard that you break a drill bit.
And X2 on what Duck Hearse said, check your coils very closely as well as the spark plug wires. Seen a few broken fans damage the coils before when they start whipping around.
Thu May 22, 2014 5:00 pm
Thu May 22, 2014 7:45 pm
Left hand drill but will get the broken studs out.
Replace fan, ring and use regular bolts with blue loctite, flat washer and lock wager
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Thu May 22, 2014 7:49 pm
Appreciate the info guys
1754GT 35GTR
Thu May 22, 2014 7:57 pm
I don't know if it will make you feel any better. But Briggs just stopped installing those grass shields on the marine edition motors.
Thu May 22, 2014 8:20 pm
better round up your parts tomorrow - closing in on a holiday weekend
Thu May 22, 2014 8:45 pm
1754GT 35GTR
Thu May 22, 2014 8:55 pm
This is why this should be the first thing on anyone's list to do to there motor. Take the grass catcher out and cut the studs down and put them back in. Seen it a dozen times or more. Cheap insurance.
http://204.197.244.166/~mudmotor/mmt_v2 ... =3&t=43639
viewtopic.php?f=3&t=29361&start=0
viewtopic.php?f=3&t=47371
viewtopic.php?f=3&t=52918
Fri May 23, 2014 4:34 am
Fri May 23, 2014 5:43 am
wow - thanks for sharing Will, that was very insightful.
Fri May 23, 2014 6:48 am
I replaced that studs with bolts, i think m6. I kept the ring, used washers and lock washers along with blue locktite.
17x54 Extreme W/ GTR-35L Stage 1
Fri May 23, 2014 8:10 am
When (not if) those studs break off, it can potentially cost $300 or more to fix everything they can tear up. The blower housing, flywheel cage, fan, coils, etc...
Fri May 23, 2014 8:36 am
Thanks Will
1754GT 35GTR
Fri May 23, 2014 10:10 am
I know I need to reuse ring, I assume this triangle bracket is not needed one grass screen removed?
Samsung S5
Thu Jun 05, 2014 10:53 am
Correct
1754GT 35GTR
Thu Jun 05, 2014 10:55 am
Thanks bud
Samsung S5
Thu Jun 05, 2014 11:02 am
So this is what it should look like correct
Samsung S5
Thu Jun 05, 2014 12:31 pm
Hopefully Boat dr will chime in but he told me those bolts will basically crush that ring so he takes the tower bolts and cuts them down where a socket will fit on the bolt. At least that's how I did mine from his suggestion.
1754GT 35GTR
Thu Jun 05, 2014 12:38 pm
That will work. Mine are cut down like Roy said
Thu Jun 05, 2014 12:43 pm
I just got new ss hardware with my ss bolts as lock washers and ss fender washers. Tightened until I saw washers begin to distort. Used blue loctite
Samsung S5
Thu Jun 05, 2014 12:52 pm
Those tower bolts have a shoulder for a reason regular bolts aren't gonna fill up the hole space in the fan shroud and support ring= gonna spell disaster at later date
Sent from my iPhone using
Thu Jun 05, 2014 1:04 pm
So what route should I go, reuse tower bolts , thought marshjb sod he just new hardware. Thanks for the help, not going on deaf ears
Samsung S5
Thu Jun 05, 2014 1:09 pm
Thu Jun 05, 2014 1:10 pm
Thu Jun 05, 2014 1:13 pm
10 4 so you think I half inch sticking out is fine. Thanks aka for getting back with me bro,
Samsung S5
Thu Jun 05, 2014 1:18 pm
Yes that will work!!
Thu Jun 05, 2014 1:23 pm
Yes, cut that line and make them all the same
Thu Jun 05, 2014 1:24 pm
Thu Jun 05, 2014 1:25 pm
10 4 cutting now.
Samsung S5
Thu Jun 05, 2014 1:27 pm
Best pic I have of mine.
If you have a little scale, you can weigh them after you cut them and make sure they are the same.
Thu Jun 05, 2014 1:58 pm
Nice call on that Owen, got two at 19.3 grams other at 19.4.
Samsung S5
Thu Jun 05, 2014 2:46 pm
Thu Jun 05, 2014 2:52 pm
It's been around for years, back when I could have fun lol. My career doesn't allow it now lmao
Samsung S5
Thu Jun 05, 2014 3:05 pm
Can't believe you actually weighed them :lol:
Thu Jun 05, 2014 3:07 pm
