It is currently Thu Dec 18, 2025 11:15 am
[ 6 posts ] |
new build is having problems
Kja0792
Ok had to buy a new block and pretty much starting over...got new crank and bps rods with cut stock pistons put it together and I'dk if I have something together wrong but this thing is locked up......it isn't even spinning over with a wrench on the flywheel... I've rechecked almost everything excepts pulling the pistons back out but most likely will do that tommorow... anybody put one together and it acted funny like it was really tight
| Thu May 29, 2014 4:15 pm |
SCmudder7071
 Re: new build is having problems
Sounds like you have connecting rods reversed. Can you see the numbers on the rods? I can't remember which one goes where tho...
_________________ 1754 Extreme/LAProp Stage 2 GTR
| Thu May 29, 2014 5:11 pm |
Kja0792
Left is number one right is number 2
| Thu May 29, 2014 5:21 pm |
caddobrook
very simple thing, but you didn't by chance somehow block the vent that comes out of your valve cover did you?
If that got plugged or blocked somehow, it won't turn over....
| Thu May 29, 2014 6:25 pm |
Kja0792
Valve covers aren't even on... no plugs in.. just won't spin over
| Thu May 29, 2014 6:27 pm |
SCSuperfly
Did you use a new case gasket or leave it out? It has to have it unless you do some machining. The gasket is part of the clearance. Just an idea. ???
_________________ Modded 36 PD draggin' around an 1848 PD boat backwards!
| Tue Jun 03, 2014 10:15 pm |
[ 6 posts ] |
