It is currently Mon Jun 30, 2025 7:02 am
Reply to topic  [ 27 posts ]
 GT1 throttle grip
Post GT1 throttle grip
I don't know if it's me or not, but I broke my second throttle lady night. The plastic shatters. They replaced the first one with no questions asked, but the first outing I broke another one. Have any of you replaced yours with a metal one?
Sat Jun 14, 2014 9:29 am
Post Re: GT1 throttle grip
Yep. Lots of folks have. Use the search feature on here or Google it. Plenty of info
HOTSAUCE170 wrote:
Sat Jun 14, 2014 9:43 am
I'm not getting any results. Looks like my new phone got me on auto correct in the title!
Sat Jun 14, 2014 10:27 am
Use google. Type in mmt throttle lever. Or look at the bps throttle lever that mud buddy sells
Sat Jun 14, 2014 10:37 am
viewtopic.php?t=32559. Here's one
1754 GTB / 35 GTR
Sat Jun 14, 2014 11:00 am
bps works pretty good
Sat Jun 14, 2014 11:34 am
if you dip coat the handle in plastic coat (several layers) it makes it a little nicer
Sat Jun 14, 2014 11:45 am
Baron I like that idea maybe make it a little more comfy on those long runs
Sat Jun 14, 2014 12:12 pm
What's that on top of the tiller control box :?: New stuff everywhere these days.
EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Sat Jun 14, 2014 12:59 pm
How much is that bps grip
1852 Dfou custom 35gtr
Sat Jun 14, 2014 1:29 pm
I've sold about 15 bps throttles in the last month
Sat Jun 14, 2014 1:31 pm
Sat Jun 14, 2014 2:01 pm
Will the bolt right on to the old handle or do the need to be modified
Sent from da mud hole
1848 Uncle J and 37 EFI GTR
Sat Jun 14, 2014 3:16 pm
Sat Jun 14, 2014 3:47 pm
You will have it down on the first trip. It still happens to me from time to time after 4 years. As far as I'm concerned it won't hurt anything. The engine will just die.
Sent from my HTC One mini using Tapatalk
Sat Jun 14, 2014 3:52 pm
Sat Jun 14, 2014 4:24 pm
Sat Jun 14, 2014 5:46 pm
Sat Jun 14, 2014 5:47 pm
The bps grip is 60$ with the cables or 50$ w/o the cable. And i would recommend not using the cable on the stock the s connector isn't the same size as the one for the gtr.
Sat Jun 14, 2014 5:50 pm
Sat Jun 14, 2014 6:55 pm
Sat Jun 14, 2014 7:57 pm
if you dip coat it be sure to give it a once over with course sandpaper (I think I used 60 grit) and clean it off i used acetone. The only way I got paint to stick to the mounting without cracking really bad was put some enamel in a cup with hardner and dip it in, 2 coats I put older bolts in bolt holes and removed bolts when paint started to setup and cleaned up with razor blade. I also gave the mount a once over with course sandpaper.
now will it stick - I don't know but looks cool and has taken a few likes so far,,,
Sat Jun 14, 2014 8:41 pm
Sat Jun 14, 2014 9:19 pm
Mikunis for both. For my dad's motor and mine.
Sat Jun 14, 2014 9:21 pm
9-10 bucks @ home depot - in paint section?
Sun Jun 15, 2014 9:28 am
I also noticed GT runs throttle cable close to engine - thats ok I get it - but you want your cable to have as gentle as turns as possible also, this is what I did, used 1 zip tie on fan cage and a insulated wire hold down on engine
Sun Jun 15, 2014 9:38 am
here is what you need 1/4 inch drill to drill out hole on wire hold, small piece of vacuum line (split on screwdiver) to fit on cable and install
Sun Jun 15, 2014 9:43 am
Users browsing this forum: No registered users and 145 guests
