It is currently Sun Apr 12, 2026 12:35 am
Reply to topic  [ 9 posts ]
 Welding U-Joint Key
Post Welding U-Joint Key
Looks like Beavertail pops a tack weld on the ket to the drive shaft from Factory. GO Devil does not.
Is it okay to do this to do this? Looks like a good way to ensure no movement in the key but will it cause problems changing the U-Joint if ever needed?
Anybody have experience with this?
Reason I ask is that I have had the key shift before on the drive shaft to the top joint.
1548 weldbuilt 13 hp GD Crawfish
Thu Aug 07, 2014 6:42 am
Post Re: Welding U-Joint Key
We have done it in the past and it wont hurt anything during disassembly or reassembly if you have to do repairs but can make it that much more labor intensive trying to make everything line up to get the parts to slide together. We just recently started tapping a hole directly above the keyway in the yokes to sink a set screw and loctite it to hopefully take out any play the key might have.
1436 Lowe
Thu Aug 07, 2014 7:52 am
I have been putting a cup point set screw on top of the key for several years now. This really helps to stop fretting of the set screws on the shafts. I also put a collar on the PTO shaft to fill the space between the top UJ yoke and the shoulder on the PTO. I squeeze the end yoke against this collar with a bolt in the end of the PTO. If you do the collar thing you need a way to find the "sweet spot" for the UJ. I do it by using a UJ with a center "H" yoke between the end yokes. This stops all fretting and works great.
Mark F. Cheney
on the Great Salt Lake marsh
Thu Aug 07, 2014 7:21 pm
Thanks for the input guys. I appreciate it.
Fri Aug 08, 2014 7:35 pm
I have a small tack on mine with the MIG... A good bump with the grinder knocks it loose and there's not much to clean up afterwards. Worked great for a while now.
-Custom pool noodle
-stage 4 water wings
Fri Aug 08, 2014 9:56 pm
It has been a while, but I believe with my old motor we hit each side of the key with a tap so that it formed a mushroom at each end and couldn't slide out.
1654 Grizzly
'13 35 GDSD
- My Wife
Fri Aug 08, 2014 10:07 pm
I think you'll be fine tacking the outside ends of the square key to the u joint. If you leave the square key about a 1/4" long, then tack weld the top of the key to the joint you will avoid welding it to the shaft at the same time. Its a great safety to hold the key in place so you don't lose it even if the set screws loosen up.
Sat Aug 09, 2014 3:43 pm
Thanks y'all, I'm going to weld it this week.
Sun Aug 10, 2014 1:08 pm
