It is currently Sat Jun 28, 2025 6:17 pm
Reply to topic  [ 18 posts ]
 governor lock/block question
Post governor lock/block question
Today I got the throttle lined up and put the governor block on that CB sent me. I did as BB told me and I was over 5k at half throttle. I even tried turning the other way with no success. Since my motor is from 2005 does that have anything to do with getting the rpms under control?
Any suggestion's?
18x48 GDSD boat
Fri Aug 29, 2014 7:16 pm
Post Re: governor lock/block question
Out of the water with no limiter and an aftermarket carb that bypasses the governor, the motor will turn up till it blows up.
Fri Aug 29, 2014 7:20 pm
You can run an external rev limiter, I believe mud buddy sells them.
the gov block only locks the mechanical gov in place - the rev limiter in the newer engines is built into the coils, you'll need an external rev limiter or just be careful - kaboom
Fri Aug 29, 2014 7:21 pm
The hockey stick looking shaft is the governor shaft that you are locking in place...so you need to turn it to where the paddle is holding the part of the governor gear that moves outward in the position it is in when the motor is at idle. Hope the pic helps some.
Fri Aug 29, 2014 7:23 pm
can that "hockey stick" and gov gear be removed and shaft hole plugged when doing a cam?
Fri Aug 29, 2014 7:26 pm
Yes sir! Either that or cut the lower part of the shaft off and remove the gear from the case cover. Just gotta make sure whatever you plug the hole with doesn't come loose and fall in the sump. :P
Fri Aug 29, 2014 7:33 pm
I always likes to use a bolt, and then put the washer and lock nut outside the block so you could see it.
Fri Aug 29, 2014 7:39 pm
sorry about jacking your thread net - hope your ? got answered
Fri Aug 29, 2014 8:23 pm
The old governor arms were crimped on the bottom to where the could only slide up so far u could cut it off rite under the crimped part and cut the top off level with the block and drill and tap the governor rod and just put a flange head in it and cost about 3$
Sent from my iPhone using
Fri Aug 29, 2014 8:48 pm
Hell just tap the hole in the block itself.
Fri Aug 29, 2014 9:08 pm
I will order a external rev limiter. Thanks guys.
18x48 GDSD boat
Fri Aug 29, 2014 10:37 pm
No need for that they don't last more than 3 months anyway u don't need it lol just learn hand control
Fri Aug 29, 2014 10:39 pm
Whatever you do, don't rev it to 6750 on the trailer...
:lol: :lol: :lol:
Fri Aug 29, 2014 10:40 pm
Fri Aug 29, 2014 10:53 pm
Sat Aug 30, 2014 4:05 am
really good stuff guys - thanks now I'll have some thing to do when it freezes up here
Sat Aug 30, 2014 7:06 am
Sat Aug 30, 2014 10:33 am
Users browsing this forum: Google [Bot] and 150 guests
