It is currently Fri Jul 18, 2025 2:46 am
Reply to topic  [ 10 posts ]
 Pro drive & excel boat
Post Pro drive & excel boat
Found a very good deal on a sw1651 excel boat. How well do you guys think this boat will do with my 27 prodrive on it? Normal load is 2 guys(220 a piece) and about a dozen decoys. Btw motor is going to evt this summer for a little work.
Sat Jan 23, 2010 7:50 am
Post Re: Pro drive & excel boat
It should be a good boat. I am not sure on the transome angle, I seem to recall excel having less transome angle than the PD's like. Not that its a huge deal. Quick fix with some shims on the motor mount.
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Mon Jan 25, 2010 9:55 am
i have a sw17x54 with a 45hp mud buddy get about 20 with two people and 4 dozen decoys, excel boats dont turn that easy also alot of sliding
Mon Jan 25, 2010 2:22 pm
Hizzoner on here has an 1851 with a 36. He should post on here, if not PM him. He has some experience with excel and prodrive combos.
Mon Jan 25, 2010 5:59 pm
White Cracker---you should be running high 20's with that load and a 45 hyper. Definitely not just 20mph. Something is not right with your setup or your engine. And yes, my Excel was a sliding son of a gun too.
Oltcudown--That 27 PD should do pretty well on the 1651 with the load you described. Probably a 20mph boat, maybe a little better. The excel hulls are overbuilt and tend to be heavy. If you add a 3rd man and gear it will be very noticeable. If possible, I would go with a 36 on that hull.
Mon Jan 25, 2010 6:41 pm
oh yeah i know somethings gotta be wrong i got a small prop on it and factory muffler, wonder if that could be part of the problem. and the next boat i buy is going to be gator trax
Mon Jan 25, 2010 8:17 pm
If I remember correctly, the 1651 is not designed for a mud motor. It is probably a .100 gauge hull and may have some cross bracing....not sure.
The 54" bottoms slide a whole lot more than the 51". I really like my 1851, but it really doesn't matter in this situation. The boat you are talking about, I believe, is a different animal in that it was designed to run with an outboard (I think).
I'm not as informed as I used to be :lol:
Mon Jan 25, 2010 8:37 pm
I believe he has the SW version....
http://www.excelboats.net/Shallow%20Water%20Series.html
The 17 inch - 17 degree transom is optimized for the MudBuddy
but the boat should be .100 gauge - slick semi-vee - tripple tapered chine
with longitudinal bracing....
We don't see many here in Texas --- let us know how she does solo
and loaded.....
Eat - Sleep - Hunt ! ! !
Mon Jan 25, 2010 9:19 pm
you are correct gigafowl. Its the shallow water 1651, 20 in transom, and .125 gauge. Its not a semi-v, it's a flat with a pointed bow. Does anyone know what degree transom the pro drives perfer.
Tue Jan 26, 2010 7:42 am
I had an excel. Just my opinion, It was too heavy. Didnt perform slid like crazy and not nearly as tough as my Phowler. Just my .02
The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides
It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown
Greater love has no other than this that he lay down his life for his friends. John 15:13
Tue Jan 26, 2010 9:53 am
Users browsing this forum: No registered users and 116 guests
cron
