It is currently Thu Apr 09, 2026 11:45 am
Reply to topic  [ 7 posts ]
 Long tail Driveshaft: Oil or Grease??
Post Long tail Driveshaft: Oil or Grease??
I'm in the process of building a 18hp longtail. I'm wondering if I could just fill the whole drive tube with gear oil instead of having grease zerks at all the bushings. My drive tube is 1" ID with a .750 shaft, bronze oilite bushings. it wouldn't take much oil and it would be easy to change.. Any thoughts?? What are the advantages/disadvantages?
Thanks, Greg C.
Wed Sep 03, 2014 2:49 pm
Post Re: Long tail Driveshaft: Oil or Grease??
The longtail manufacturers have been putting grease in them for years. There's probably a good reason why they don't use oil.
Sent from my beeper
Wed Sep 03, 2014 3:41 pm
Ya I'm sure this a reason I just wish I knew what it was! I hate to think of all that grease accumulating in the tube.
Wed Sep 03, 2014 3:47 pm
Wed Sep 03, 2014 6:51 pm
Probably the viscosity of the oil. Grease is a lot thicker. Those seals let grease out even when in good shape. Oil would not fare as well
Wed Sep 03, 2014 7:26 pm
I'm going to try the oil, I'm building a resevoir and goin with a double seal setup. I ordered Biodegradable gear oil. that is enviromentally safe. That way if I lose a little, I won't be polluting my favorite hunting spots. I'll post some pics of my build when I'm done.
Sat Sep 06, 2014 3:13 am
Just get a backh20 glider kit. Then you don't have to worry about grease loss.
23 swomp/ 1542 tracker
Sat Sep 06, 2014 4:55 am
