It is currently Thu Nov 05, 2026 6:50 am
Reply to topic  [ 114 posts ]  Go to page Previous  1, 2, 3
 SD build
Post Re: SD build
Very good speeds post pics neg!
1850 Uncle J
Delta Performance level 4 GTR
Sat Sep 27, 2014 8:31 pm
Post Re: SD build
That little boat was getting 17 with a longtail. You need more power. You should be getting 30 at least before you stop trying :)
Sat Sep 27, 2014 11:03 pm
Post Re: SD build
Going to tear the motor down today and see what's going on with the internals.
Sent from my beeper
Mon Sep 29, 2014 6:53 am
Post Re: SD build
Everything looks good. I'm just going to run it till it blows! Got a few spare motors layin around I can throw on it anyway.
Sent from my beeper
Mon Sep 29, 2014 8:16 am
Post Re: SD build
You ever get a solo speed?
35 GTR chasin a BBC 1848
Mon Sep 29, 2014 8:33 am
Post Re: SD build
Mon Sep 29, 2014 8:54 am
Post Re: SD build
Man imagine the speeds you would get with a prop on that thing!!! :lol:
1850 Uncle J
Mon Sep 29, 2014 9:34 am
Post Re: SD build
Lol
Mon Sep 29, 2014 4:37 pm
Post Re: SD build
Mon Sep 29, 2014 4:39 pm
Post Re: SD build
We're did you get your pulleys and belt from?
Mon Sep 29, 2014 8:37 pm
Post Re: SD build
His came off a copperhead, but check out this website.
https://worldindustrial.com/p-22l100-11 ... dpbsquote="Muddy ducks7"]We're did you get your pulleys and belt from?[/quote]
Tue Sep 30, 2014 8:55 am
Post Re: SD build
I've got a 9x8 and a couple of 9x6's if you want to try them out on there.
That's gunna be a hole grabbing little fukker there!
Wed Oct 08, 2014 1:57 am
Post Re: SD build
What size shaft is that? Id like to see how you did the seals in outdrive. You ran 4 bearings total, shielded or sealed? Bearing caps in both ends? Need some ideas for my dixie as far as seals go. There is none in the pulley side, just a bearing cap, and Im getting grease in belt housing if full.
Wed Oct 08, 2014 7:22 am
Post Re: SD build
Built me a pulley cover.
Sent from my beeper
Wed Nov 12, 2014 9:17 am
Post Re: SD build
Sent from my beeper
Wed Nov 12, 2014 9:25 am
Post Re: SD build
Wed Nov 12, 2014 9:26 am
Post Re: SD build
That thing looks like its goin 100 mph on the trailer!
Wed Nov 12, 2014 12:03 pm
Post Re: SD build
Looks good. Got any video of it running in the water?
18x40 skiff/35 hp GTR
Wed Nov 12, 2014 1:17 pm
Post Re: SD build
Wed Nov 12, 2014 1:18 pm
Post Re: SD build
Well I finally got a good motor for it and got it running yesterday.
Was going to get a 14 hp kholer but decided against it.
Ended up with a 10 hp Vangaurd. Seems like a decent motor.
Going to get the kill switch and starter rigged on the handle soon so I can put it in the water.
If everything goes right I will be using this most of the season.
I will get some speeds when I get it on the water.
Thu Sep 01, 2016 6:00 am
Post Re: SD build
Thats a nice motor! You gonna mod it?
Thu Sep 01, 2016 3:14 pm
Post Re: SD build
Negative. Gotta save my money for my big rig!
Sent from my beeper
Thu Sep 01, 2016 7:38 pm
Post Re: SD build
Finally got it rigged up. Running good and ready for a test drive!
Sent from my beeper
Wed Sep 14, 2016 4:57 pm
Post Re: SD build
That's pretty dam cool :ugeek:
Wed Sep 14, 2016 7:22 pm
Post Re: SD build
I'm just glad I will get to use it this season finally! As long as nothing breaks!
Sent from my beeper
Wed Sep 14, 2016 9:07 pm
Post Re: SD build
bout time update this thread and its time for more info again!! :D
Wed Dec 21, 2016 4:41 pm
Post Re: SD build
Running good so far. Used it a few times this year.
Doesn't run as fast as the 12 hp I had on it at the beginning but still goes pretty good!
Definitely need another rig though. Can't haul but 2 people and gear in this one.
I'm going to build another one this summer to have a haul rig.
Thu Dec 22, 2016 6:43 pm
Post SD build
Had to re rig my handle. It broke twice. It was only made out of emt.
Had some 1 1/4" square bars so had the end turned round and bolted it on this time. Hopefully it will hold up.
Speeds are about 20 solo and 17 with 2 people.
Wed Jan 18, 2017 8:14 am
Post Re: SD build
Just out of curiosity , how low do you have the drive shaft in relation to the boat ? Like is it flush with the bottom of the boat?
Mon Feb 06, 2017 12:46 am
Post Re: SD build
I know you said it's running same gear ratio as 12hp copperhead, but could you say what that is? I'm putting a Briggs animal that's been modded for more bottom and mid range torque on a Dixie 6.5 frame. Should be around 10-12hp running at 5k rpm, with 6.1k rev limiter. My gear ratio is 1.43 to 1. I'm trying to decide whether to go 10x8 or 9x7, so I'm curious what ratio your using with 10x8
Wed Jun 07, 2017 2:49 pm
Post Re: SD build
Man I'm not sure what ration it is. I can't remember what tooth pulleys are on it.
I'm running a 10 hp now and a 10x8 it just rite. I think a 9x7 would be way to small.
Wed Jun 07, 2017 9:27 pm
Post Re: SD build
Sat Jun 10, 2017 12:08 pm
Post Re: SD build
What kind of rpms at those speeds?
Wed Jul 19, 2017 12:12 pm
Post Re: SD build
Wed Jul 19, 2017 12:33 pm
