It is currently Tue May 13, 2025 10:52 am
[ 8 posts ] |
WingCutter
 New GT lower unit Torque
On the new GT lower unit how do you adjust for Tiller Torque. The older unit had the adjustment tab but the new one is cast. I called GT and they said my only option was to move weight around. When I am by myself it is very bad. Motor is dead center like they told me to do. It is on a custom flat 1854 with no ribs. Fuel tank and batteries are in the front. The load goes as far to the port side (left) as I can get it. They are lined up batt, fuel tank and then batt then some left over space. The Batteries are class 31 so they are nice and heavy. My thought was to get everything over to the Port side to counter my weight on the starboard. Any ideas would be appreciated.
Tue Dec 09, 2014 2:20 pm |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
 Re: New GT lower unit Torque
I moved mine on the transom slightly off center - but shifting weight in boat with hunt load also makes huge diffrence, with my boat 18'60" gear in the middle people up front works best.
If you mount off center be sure to test with load in the boat. I set it with no load and it is smooth as hell, with load it can be a bear to handle until you start shifting weight.
my .02
_________________ that's going itch when it dries
Tue Dec 09, 2014 2:34 pm |
baron von
what they really need is a tiller tension control bolt/mechanism - like most outboards.
Tue Dec 09, 2014 3:07 pm |
LB200
In my boat I need more weight to the starboard side to get it to track the best. If it is heavy on the port side then it wants to go to port like crazy. Overloaded to the starboard and I can relax and let it run. Mine is super sensitive to weight distribution in all directions
Tue Dec 09, 2014 4:51 pm |
jc
^^^This^^^ move weight to the right and try again.
Tue Dec 09, 2014 6:18 pm |
WingCutter
I'm gonna move one of the class 31 batteries over to the right and see if that helps!
Tue Dec 09, 2014 9:15 pm |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
Just fashion and attach a small tab to the skeg. Out of wood first so you can test various degrees of deflection.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Tue Dec 09, 2014 9:23 pm |
deadbird8
Wed Dec 10, 2014 4:29 am |
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 222 guests |
