It is currently Sun Jul 20, 2025 10:59 pm
Reply to topic  [ 24 posts ]
 trailer preferences
Post trailer preferences
looking to build a 1854 flat bottom. whats the best trailer. I want a solid winch platform and good side bunks that are gonna hold up
Sun Mar 08, 2015 1:05 am
Post Re: trailer preferences
If you are in Texas or Louisiana....its hard to beat a McClain. Those things last forever
1844 GD with 35HP GDSD
Sun Mar 08, 2015 6:31 am
X2 on McClain!
1854 Brotha Breaux chased by 36 PD!
Sun Mar 08, 2015 8:05 am
I will sell you my all aluminum McClain. I have an 1848 on it right now, will fit an 1854 no problem with a small adjustment at the side bunks, extended tongue, torsion axle, pm me if you are interested
Crisis defines character
Sun Mar 08, 2015 11:21 am
Best trailers: Myco, Sport Trail, Owens & Sons, Float On.
MoMarsh Fatboy/2 Honda
Sun Mar 08, 2015 2:22 pm
Magic Tilt is making a real nice aluminum trailer right now, perfect for these rigs. Boatdr sells them in the New Orleans area.
I'd swap my McClain for one in a second.
Sun Mar 08, 2015 2:58 pm
20 year old ez loader I bought for $600 off sportsman. They got deals, just gotta search fellas
Sent from my SAMSUNG-SM-N900A using Tapatalk
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Sun Mar 08, 2015 3:02 pm
I'm looking at buying a tandem axle Fast Load aluminum trailer . Includes PVC guide on post and sealed oil system bearings instead of greased bearings. They are the cheapest Iv seen online. Looks like a solid trailer. 2095$
Sun Mar 08, 2015 3:06 pm
Sun Mar 08, 2015 3:12 pm
What about having the boat builder build one?
Sun Mar 08, 2015 3:20 pm
Sun Mar 08, 2015 3:33 pm
Why is that. I had a guy build the frame for me. Then it put it all together.
Sun Mar 08, 2015 4:07 pm
Mcclain and magic tilt are both good trailers, I always get aluminum. The sealed bearings are really sweet!
Sun Mar 08, 2015 4:52 pm
Boat dr
http://www.gatorglide.com/
gatorheads@comcast.net
Sun Mar 08, 2015 6:30 pm
My aluminum magic tilt is very nice. My boat sits much lower than it did on a maclain.
Sun Mar 08, 2015 8:38 pm
The lower the boat the better as it gets off the trailer quicker and easier. Also being lower makes it easier to get you and your gear in and out.
Sun Mar 08, 2015 8:52 pm
Just about every trailer I have had I've redone the boards to sit lower. Even with V bottom boats. It makes your life easier. There was a thread not long ago discussing this. I'll be redoing the brackets on my new McLain before I ever take it to the ramp. I'll have the boat off of it for gator glide, so, why not?
-Custom pool noodle
-stage 4 water wings
Sun Mar 08, 2015 9:40 pm
Sun Mar 08, 2015 10:00 pm
It takes some redrilling but it's easy. I haven't decided if I'm going to use the little L brackets or just bolt my boards straight to the trailer on top of the channel iron cross members. Either way you have to drill holes. Make sure every hole you drill gets re-sprayed with cold galvanizing and dries before you stick bolts back thru.
My last flat bottom trailer I just used 3 2x6's cut to length and bolted the to the trailer with stainless carriage bolts. I let the impact sink the heads into the wood so they didn't stick up and rub the boat. Carpeted over them and you could never tell a difference. Looked good, boat was way lower on the trailer and launched/loaded easier because the side bunks actually touched the boat. There wasn't a bunch of room to go side to side. Made loading in wind/current much easier.
-Custom pool noodle
Sun Mar 08, 2015 10:14 pm
Sun Mar 08, 2015 10:16 pm
I don't have an issue side to side. I just have to go so far back, I have to climb in bed of truck and climb on trailer to work winch. I gotta go way to far to launch and load
Sun Mar 08, 2015 10:18 pm
I'm looking forward to being able to back mine down where it's just over the water and shove the big bastard off the trailer lol.
My old boat didn't have GG but I had the trailer set up so well I could load that thing in a damn strong current after having WAAAAY too many sodas. Lol
-Custom pool noodle
Sun Mar 08, 2015 10:23 pm
Sun Mar 08, 2015 10:44 pm
I know you guys have seen this. I put GG on the bucks and I have zero wear on my boat and don't have to worry about trapping sand in carpet or premature rotting from holding moisture. Tperkins beat me to it in the video and hopefully chime in if he found any negatives about it.
Also may want to conceder a raised roller in the back
This is the back of my airboat but works the same on my mud boat. I put just under the water for loading and it holds the boat on so I can hook the nose. When launching you just let it float over it. This one is pinned so I can take it out and dry launch
Mon Mar 09, 2015 6:23 am
Users browsing this forum: No registered users and 135 guests
