It is currently Tue Dec 23, 2025 3:26 am
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 grease inside housing being thrown by belt.
Post grease inside housing being thrown by belt.
If I pumped too much grease would it possibly throw a good bit of the new greese around inside housing? I didn't see grease in there last time I looked. I also didn't see much old grease come out. Maybe the seal broke in there?
What do yal experts think?
Tue Mar 10, 2015 6:27 pm
Post Re: grease inside housing being thrown by belt.
1. is it a GTR?
2. how many tubes did you pump in - I think the record is now at 5
Tue Mar 10, 2015 6:40 pm
Haha. No its a mud buddy. I bought it used figured I'd put some new grease in it for a warm and fuzzy. I removed little relief screw and gave it about 10-15 pumps. Nothing crazy. Let it ooze out. Put the screen back in next day I ran the boat. Took the cover off and saw all the blue grease I put in thrown around. Seal? Or normal?
Tue Mar 10, 2015 6:48 pm
Tue Mar 10, 2015 7:01 pm
Maybe the pic will help
Tue Mar 10, 2015 7:02 pm
you'll probably need to clean that up a bit, might have just put to much grease in
Tue Mar 10, 2015 7:19 pm
Looks like the seal behind the gear is blown
1754 With Level 3 GTR
Tue Mar 10, 2015 7:21 pm
Yep, gotta change the seal.
Tue Mar 10, 2015 7:24 pm
Change the seal
Tue Mar 10, 2015 7:25 pm
OK, will change the seal. I'm guessing call mb with my serial number they will know what I'm talking about? I also have a new prop I want to put on so I mine as well replace all seals?
Tue Mar 10, 2015 7:27 pm
That or call boat dr.
Tue Mar 10, 2015 7:36 pm
^^ what he said - 504-737-1203 very easy guy to deal with
Tue Mar 10, 2015 7:37 pm
where you at - there is a pretty good guy up here to if you're up in the northland 8-)
Tue Mar 10, 2015 7:40 pm
Do yourself a favor and call boatdr. You don't want the hassle of dealing with mud buddy.
1854 Prodigy DPE Level 3 HDR
Tue Mar 10, 2015 7:44 pm
I'm in SC. Thanks for yals help. What kind of a pain in the ass is it to replace this seal... Just looked at it, looks like a lot of bolts hha
Tue Mar 10, 2015 7:51 pm
it's not that bad - but it does remind me of a funny story,
A penguin brings his rig in to the shop because it's leaking grease, the guy says it'll be a few minutes before he can tell what is leakin' and tells the penguin to go across the street and get something to eat or drink, so he does and has a ice-cream cone, but he's penguin and doesn't have any arms/hands and gets ice-cream all over his face.
penguin goes back to the shop and the mechanic says "looks like you blew a seal" and the penguin says " no it's just ice-cream" :lol:
Tue Mar 10, 2015 8:01 pm
^^lmao
Tue Mar 10, 2015 8:04 pm
Ordered the seals from boat Dr. Thanks gents. I'm sure I'll have questions when they arrive. Thanks for the help
Wed Mar 11, 2015 10:14 am
Where are you at in SC?
Wed Mar 11, 2015 10:35 am
Stationed on Paris island. Live in Beaufort .. I'm from merrit island fl ...
Wed Mar 11, 2015 10:52 am
Gotcha. If you can't get it figured out give Kevin Lusk a call at Lowcountry Mud Buddy. He's in Moncks Corner.
Wed Mar 11, 2015 11:01 am
"There's nothing a duck hunter hates more than another duck hunter."
Wed Mar 11, 2015 12:07 pm
Its simple to change, the dixie motors are setup very similar to MB. I actually just had this issue. I filled with grease, (whole shaft housing held 2 tubes of grease exactly.) I pulled the relief plug and filled until it came out. I ran the boat this past weekend and had a small amount come out into the belt box. I may have blew the seals out, but Im gonna run it for a little bit more and see if any more slings out. When I pulled the relief plug the second time the grease seemed pressurized and actually came out of the relief plug on its own.
Wed Mar 11, 2015 1:05 pm
OK started disamsemblimg everything. Got it off I'm to the point where I think I need to take the gear off. How?
Any good existing threads explaing this? I've attempted the search bar with limited luck.
Wed Mar 11, 2015 5:01 pm
Wed Mar 11, 2015 5:56 pm
I can't find any step by step to replace seals
Wed Mar 11, 2015 6:57 pm
If you need to see a video, Google how to remove a taper lock. Should be a YouTube vid out there. On the seals I'm not exactly sure how MB did theirs. On mine I used the bearing cap and had 2 spots for seals cut. You should be able to pry them out, then they will just tap back in. If not you can try a bearing puller tool to pull them out. Then use a socket to tap the new ones in.
Wed Mar 11, 2015 7:11 pm
Got it. I'm guessing this is where it blew out...
Wed Mar 11, 2015 9:00 pm
yikes :o
Wed Mar 11, 2015 9:05 pm
Just a seal, correct baron? I was about to go to sleep until I saw your comment. Makes me wonder if it could be more than just a seal haha
Wed Mar 11, 2015 9:17 pm
I would go to sleep. If it's more than just a seal, it ain't getting fixed tonight.
Wed Mar 11, 2015 9:19 pm
Ya your right about that brstanle..
Wed Mar 11, 2015 9:26 pm
That's an easy fix man. Check out the shaft and make sure there's no marking on the shaft from that spring being against it. Other than that, throw a seal in it and roll. If you have a parts house worth a damn local to you, pull it out, take it to them and they can match it up. FYI, over-greasing will do this very thing. Keep in mind that grease expands when it gets hot during operation. If there's nowhere for it to go, path of least resistance is going to be that rubber seal every time ;) Definitely grease it ENOUGH, just not too much...
-Custom pool noodle
-stage 4 water wings
Wed Mar 11, 2015 9:48 pm
Setx , I used the boat Dr. I went ahead and ordered both seals. Thanks for the help
Thu Mar 12, 2015 5:32 am
Good deal. Easy fix
Thu Mar 12, 2015 6:48 am
Ya thanks for the p.m mudx I didn't message back hands were too greasy.
Thu Mar 12, 2015 6:52 am
When you fill the mb with grease your suppose to run in gear with relief plug out for 5 minutes. This process allows grease to expand, then you plug.
Thu Mar 12, 2015 9:47 am
Thanks for the tip Dmax, good info to know
Thu Mar 12, 2015 12:09 pm
So I took a screw driver and pushed on that seal that was blown. It popped right back in and looks normal. Is this even possible ? Has anybody ever fixed a seal by simply pushing it back in?
I already ordered the other seals just curious.....
Sat Mar 14, 2015 5:05 pm
It might have went back in but, when you add grease iam sure it will just blow back out, once they blow to me they are junk.. I would not trust it,
You can't fix stupid
Sat Mar 14, 2015 6:42 pm
