It is currently Thu May 15, 2025 12:51 am
Reply to topic  [ 35 posts ]
 Unwearable prop
Post Unwearable prop
I've seen knifes and even heard of chainsaws being diamond bladed, i was wondering if something like that would be possible with a mud prop? I know it would be very expensive but it seems like it would pay for it's self in the long run
Or is it just a rediculosly stupid idea?
Mon Mar 16, 2015 8:21 pm
Post Re: Unwearable prop
I've thought about welding something like tungsten or something very hard but I've heard it will eventually break where you weld it.
It sounds like a great idea but just not sure how to execute it!!
Sent from my beeper
Mon Mar 16, 2015 8:24 pm
I'm going to weld some stellite on the leading edges on some props. Just to try to see if it will help
Mon Mar 16, 2015 8:38 pm
I would think its something that would have to be cast? Like diamond blade or whatever else it is that wont wear and pour a cast over it to where its embedded into the metal? But I know nothing about how a prop is made so idk if that's even possible.. Lol
Mon Mar 16, 2015 8:42 pm
Mon Mar 16, 2015 8:44 pm
I really hope this thread is a joke, and I just missed the retard that inspired it somewhere else...
Mon Mar 16, 2015 10:14 pm
Mon Mar 16, 2015 10:47 pm
Negros be taking diamond crusted props and wearin some serious bling in the hood laughin at you krackers for the shinny present
Sent from the company's iPad while at work
Dont criticize a farmer with your mouth full
Tue Mar 17, 2015 5:58 am
Tue Mar 17, 2015 6:19 am
There is such a thing co in Dallas
It's called boron , the part is packed in it then in a oven , then controlled heat takes a day if I remember . It not cheap , but it is in the base metal about. .005" dose not change any dimensions used in aero space harder than alloy 6 , stellite mine prop is 4 yrs old no noticeable wear its use in the bay mostly sand
driving a gd in ur lake
and i aprove this message
Tue Mar 17, 2015 6:46 am
Talk to Kobalt. They make screwdrivers with the black tips that don't strip as bad. maybe they'll do a prop :)
Tue Mar 17, 2015 6:59 am
Tue Mar 17, 2015 4:08 pm
Damn yeah thats alot lol. But for around that $1000 range I still think it would be well worth it
Tue Mar 17, 2015 4:14 pm
Anyone try wooden prop?
Those sinker cypress logs I hit are hard as fuk. I wonder if it would work?
Tue Mar 17, 2015 4:18 pm
Tue Mar 17, 2015 5:17 pm
We are current'y testing the new alloy we use on the new Dixie lower units to see if it is suitable for propellers.
Still too early to tell, but we have high hopes.
Tue Mar 17, 2015 7:18 pm
Tue Mar 17, 2015 7:24 pm
"high" hopes at Dixie - they must be giraffe's @ss high
Tue Mar 17, 2015 7:27 pm
Tue Mar 17, 2015 8:26 pm
^^this.
Wed Mar 18, 2015 8:58 am
http://salemmaterialtechnology.com/?page_id=55.
Nitrotuff. We use this stuff sometimes on our coil tubing tools.
Stock 35gdsd skidding 1654gd
Wed Mar 18, 2015 2:44 pm
I feel like a surface hardener like nitrotuff or getting the prop nitrated would only help until the prop gets a nick in it and thus eleminates the hardening process. Why not use better materials for the prop? Machine annealed tool steel grade materials for the props then heat treat em.
Wed Mar 18, 2015 3:50 pm
Because only like 2 people will pay well over $1000 for a MM prop that only goes 28mph
Wed Mar 18, 2015 3:57 pm
I will not be one of them!
Wed Mar 18, 2015 4:04 pm
Yall say that now until someone figures it out and never has to buy a prop again.
How much you think you spend on props a year? (that run alot of shallow water..)
The first year i had my motor i went balls the the walls and burned 6 props..buying a new prop every time adds up to over $1000...that being said though i did finaly figure out that rebuilding them is much cheeper but it does still add up to be pretty expensive.
Wed Mar 18, 2015 5:33 pm
Never have to buy a prop again? :lol: At best you'll get a little better wear...diamond tip'd, cryptonite, whatever, put it in some sand, I bet you burn it up..
Wed Mar 18, 2015 5:47 pm
Get your ass out the boat and walk if it's that shallow and Sandy.
Wed Mar 18, 2015 5:52 pm
Its not that its sandy its just a silty mud around here that eats em up quick.
And i guess i worded that wrong..shouldn't have said never lol
Wed Mar 18, 2015 6:09 pm
What happens when you whack that prop on a rock and break off your hunk of diamonds
Wed Mar 18, 2015 8:25 pm
Could you use cubic zirconia(fake diamonds) to bring the cost down?
Wed Mar 18, 2015 8:41 pm
Realistically speaking, someone who can afford a true diamond blade prop more than likely wont be driving a mud boat in the marsh..
Hypothetically speaking, you better be going 1000 mph and hit another diamond to break a fukin true diamond blade prop lol
Only way I would see that possible is hitting something really hard at a funny angle and torqueing the prop to where a whole blade would come off..i've seen it done before but i think you would have to try pretty hard to break off a whole blade
Thu Mar 19, 2015 6:32 am
Im not talking about a prop completely made of a hardend material.
Same ole steel prop we use just with a harder more resistant material embedded into the leading edge.
That way the hard stuff has something to push into if you did happen to hit something hard other than a log. If you hit a big rock or concrete your gunna fuk up your motor regardless. But even when you hit a log or a stump the rotation of the prop will just throw the motor to one side. I've hit underwater stumps hard enough before that the motor shut off but not a even the smallest of nicks or dints in the prop.
Im not saying i know what im talking about it was just an idea to throw around.
Thu Mar 19, 2015 8:21 am
Next time you got a big present being given to you, just get them to buy you an air boat and stay out of the trees and you won't have prop problems.
Sat Mar 21, 2015 10:28 am
Satellite will work well until it takes a hard hit. That's when a big chunk will break off. It's super hard.
18'x54"CC Hanko/ 36PD
Sat Mar 28, 2015 4:15 pm
Users browsing this forum: No registered users and 133 guests
