It is currently Sat Jul 19, 2025 12:05 am
Reply to topic  [ 22 posts ]
 Normal Cruising RPMS??
Post Normal Cruising RPMS??
Just curious, when you are out cruising in your boat, what RPMS do you run at? Do you always run wide open? I find that my boat is most comfortable around 3800 rpms and it cruises around 24-25 MPH.
Fri Jun 19, 2015 6:53 am
Post Re: Normal Cruising RPMS??
3900
1748 Prodigy with MB 4500 Black Death
Fri Jun 19, 2015 6:57 am
I keep it around 4200.
Fri Jun 19, 2015 8:58 am
Lol 4750?
Fri Jun 19, 2015 9:05 am
It's all relative I guess. My stock 23 tops out at 4100 and I'll cruise around 3600.
Sent from my SCH-R950 using Tapatalk
Fri Jun 19, 2015 9:31 am
Do you run your lawn mower at half throttle?
Fri Jun 19, 2015 12:49 pm
7.
Fri Jun 19, 2015 12:55 pm
4100
Sent from my beeper
Fri Jun 19, 2015 12:56 pm
Fri Jun 19, 2015 1:00 pm
Run it how you feel is safe to your standards. These engines have 4700 coils, but most stock engines are lucky to see past 4300. Run it wide open trim it right and back off the throttle if you feel you want to. Otherwise run it hard if you need to.
Fri Jun 19, 2015 1:05 pm
Fri Jun 19, 2015 1:49 pm
I was wondering the same thing...my 37 EFI 2054 PD I typically run at 4000-4250 but WFO is 4250....is this about what I should expect? (Yes, I do run it at WFO quite a bit, but aren't these motors made for that??)
Fri Jun 19, 2015 1:54 pm
A stock 35 hp briggs is made to make 35 hp at 3600 rpm. Do people have thousands of hours running more than that, yes. But i dont think theyre necessarily made to do it
Fri Jun 19, 2015 2:02 pm
I usually run anywhere from 4400-4600 (best speeds) on my EFI GTR
Fri Jun 19, 2015 4:23 pm
Stock Briggs 23hp about 3400-3450 trimmed all the way down.
Fri Jun 19, 2015 8:19 pm
4250-4350...27-28 MPH
18X44 Geaux Custon Powered By MB 4500 BD
Sat Jun 20, 2015 10:05 am
I'm just starting to get some tiller time on my 31GT. Top rpm is 4150 under a load. I'm finding 3850 or so to be a pretty comfortable ride, but it's hard to keep from squeezing that throttle!
Sat Jun 27, 2015 7:38 am
My rig Planes out at 2200 Rpm Comfortable cruising Rpm is 2600-2800 Rpm. will top out at 4490. Very seldom above 4000rpm for any length of time. Alumacraft 1648 riveted Jon MB BD 4500, 38/47 gears. Hammer prop.
Sat Jun 27, 2015 9:09 am
I normally run around at about 3800 rpm. When I get faster than that I start to get more engine noise.
Sat Jun 27, 2015 9:20 am
When I was stock it was always WFO. Which was 36-3800 rpms. Now modded I can turn upto about 4500 but I keep it around 38-4000 runnin low 20s deep water. Comfortable cruising but more power when ever I need it
Sun Jun 28, 2015 7:02 pm
4300.
I only know two speeds. Idle and wot
I gave up mud motors
Mon Jun 29, 2015 6:42 am
I'm with T-Bubba on this one. If I'm running from point A to point B, it's either at idle or throttle pinned against the handle at WOT. Depending on which prop I'm running, this is either 4700 or 4500 with my current gearing.
Tue Jun 30, 2015 2:51 pm
Users browsing this forum: No registered users and 143 guests
