It is currently Sat Jul 12, 2025 3:48 pm
Reply to topic  [ 31 posts ]
 beavertail boat blind pics
Post beavertail boat blind pics
Anybody have any pictures of their boat blind, specifically a beavertail blind, with raffia grass or some other semi permanent material? It looks like I might be hunting from the boat more often this year and would like to cut down on brushing the blind every time I go out.
WC Custom 1854 huntdeck pushed by MB7000
Thu Jul 16, 2015 10:20 am
Post Re: beavertail boat blind pics
This is my old boat. Raffia over grass sheets. I have a beaver tail blind for my new boat that is getting only raffia
Every day I'm paddlin'
Thu Jul 16, 2015 10:34 am
really good boat blinds - but you got to grass them, you have to extend the travel cover straps to accomidate the grass. The travel cover is really a must
this is what I did to fit it to a boat with cat walks
Thu Jul 16, 2015 10:45 am
baron thats something else i was curious about. it looks like you went pretty heavy on the grass. does all that still fit in the travel cover?
Thu Jul 16, 2015 10:51 am
here is some pics of it before grassing - with just some cattails jammed in to break the color up
all shooting ports and dividers down
travel mode
Thu Jul 16, 2015 10:54 am
Thu Jul 16, 2015 10:55 am
Here are a couple pictures of mine with just raffia.
1854 Uncle J pushed by a gen 3 PD
Thu Jul 16, 2015 10:58 am
do you remember what colors you bought sas? thats pretty close to the color scheme im looking for.
Thu Jul 16, 2015 11:02 am
the BT blinds don't "flap" in the wind as much, hardly none, as opossed to the Avery QS I had - I really like it, when you flip that bugger open and sit down out of the wind it is really nice on cold days. it is easy to flip back closed to go pick up dead birds or tend dekes also
Thu Jul 16, 2015 11:17 am
here is the 4 colors I used - forgot what they are called - I used pretty much the same colors SAS did
Thu Jul 16, 2015 11:38 am
yeah ive used quite a few different styles of blinds and BT is definitely the best as far as ease of setup and being comfortable. i doesnt get near as cold in TX as it does in MN but you're right. on a cold windy day its significantly warmer inside the blind with the way in blocks the wind. throw a small heater in there and you can get it to tshirt temps. the only bad thing i would have to say about the BT blinds are that it takes a lot of work to get one brushed up properly in the field but this should solve my problem.
Thu Jul 16, 2015 11:46 am
I don't remember what the colors where called. If you call www.jstern.com they will send you a card with all the sample colors on it.
Thu Jul 16, 2015 2:01 pm
You can die the grass yourself to get the color right.
RIT die for clothes. Mix it up in a 5 gallon bucket and let it soak overnight.
Kool-Aid Brigade
www.southernfowler.com
Thu Jul 16, 2015 3:54 pm
I had one of these with an outboard, but how is it when the mud motor kicks up?
Fri Jul 17, 2015 5:46 am
Fri Jul 17, 2015 6:49 am
I didn't have any trouble with kick ups last year - hit a couple muskrat adobes motor clears blind no sweat; even when I push tiller down to lift prop to clear stuff (logs rocks ect) doesn't touch blind - now you cannot drive (my) boat with blind up - you can but it's a bitch
Fri Jul 17, 2015 6:50 am
Fri Jul 17, 2015 7:03 am
Fri Jul 17, 2015 11:37 am
Got the main blind done today. Still need my motor cover made and grassed and my bow cover done.
Top ports all closed up.
Fri Aug 21, 2015 12:40 pm
Nice
Sent from...wait, Where am I?
Sat Aug 22, 2015 8:52 am
Mon Sep 28, 2015 6:20 am
See if BaronVon jumps on here. We took a soldering iron and pokes holes in the material and attached mats and other material with zip ties.
Mon Sep 28, 2015 9:48 am
thats not a bad idea. how has it held up like that? any rips or fraying?
Mon Sep 28, 2015 11:55 am
This is the beaver tail with the added roof, it goes on and comes off easy. I did not notice the silver bar in the background till after I took the pic, it's painted now!
You can't fix stupid
Mon Sep 28, 2015 8:20 pm
Does that top fold up with the blind or do you have to remove the top before you flip the blind over
1754 prodigy- stage 2 GTR
Mon Sep 28, 2015 9:50 pm
Tue Sep 29, 2015 4:14 am
Tue Sep 29, 2015 8:45 am
here is a picture of how we extended the cover straps - if you burn holes in your straps/blind use a soldering iron makes nice neat little self sealing holes in vinyl material. Another thing is the cross brace bolts rusted solid in mine, due to road clearing chemicals during trailering (steel/aluminum metallurgy) note tape covering bolt - might want to add some anti sieze to them
Tue Sep 29, 2015 9:01 am
So is the top folded up in there?
Tue Sep 29, 2015 9:32 am
I don't have a "top" just the blind & grass - so the blind is folded up and stored for trailering
Tue Sep 29, 2015 9:47 am
The previous owner sewed additional strapping where it is lacking. I have so much raffia on mine, I ended up clipping two travel boots together. Bungee cords on the front to keep the wind from blowing through it is a must!
2010 GTR35 pushing an 1860 Gator-Tail Extreme
Wed Sep 30, 2015 3:06 pm
Users browsing this forum: No registered users and 122 guests
