It is currently Fri Apr 03, 2026 4:45 pm
Reply to topic  [ 2 posts ]
 $ value of modded honda 13 hp (engine only)
Post $ value of modded honda 13 hp (engine only)
What kind of $$$ do you think I could get for a slightly souped up honda 13?
It's recently had the governor removed. Installed a bigger carb jet, stronger valve springs; gas tank removed and pulse pump added with fitting for external fuel tank. I swapped an almost new oem replacement muffler for a header pipe and screw on mini muffler. Custom air filter and oil breather filter. Runs Great! How much $$$ should I be looking at?
Sun Aug 16, 2015 6:09 pm
Post Re: $ value of modded honda 13 hp (engine only)
Maybe try a go kart forum? might be a bigger market for modded small engines.
Mon Aug 17, 2015 4:44 am
