Grant97
 Cutting a Tall Transom For a Longtail
I just got a 17x46 Gator-tail boat with a 21 inch transom on a hunt deck, and my 25 long tail doesn't push as well as I thought it would. I bent up the cavitation plate, so the problem is not that the motor wont stay in the water. I think the problem is the angle of the shaft, because it seems to push the bow down and will only reach about 2700 rpms. I was wondering if there was anything I could do other than cutting the transom down to make it run better. And if I did end up having to get it cut could it ever get close to how strong it was originally if I want it built back up for a GTR.
| Sat Aug 22, 2015 5:16 pm |
rob_rides_03
Joined: Tue Oct 13, 2009 3:31 pm Posts: 202 Location: NJ
 Re: Cutting a Tall Transom For a Longtail
Hey, I run a 1644 tall transom gator trax with a tall transom 84" drive mud buddy.
You're problem might definitely be the angle and the drive length but your rpms are really low. I turn my prop at close to 4000 at wide open. What are you running for a load when your only getting 2700. I've run a few different props on mine.
A fresh 9x7 I get 3300rpm and the motor bogs hard in the mud. 9x6 I get 3600rpm and as it wears I get 4000
I just ordered a 9x5 and going to see how that does.
I've only ever tried mud buddy tiger props
| Tue Aug 25, 2015 6:47 am |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
Been there done that. Wouldn't do it again. Thats a nice boat. If you are thinking about possibly putting a surface drive on that boat one day, then don't cut the transom. Its not gonna be cheap if you cant fabricate/weld aluminum on your own.
Id put up with the bad performance until i had the funds and sell the longtail.
| Tue Aug 25, 2015 10:22 am |
Johnny-O
Something is definitely wrong. You're at least 1000 rpm's low. What does it turn out of the water?
1744 Phowler Prowler, 23 Dixie
| Tue Aug 25, 2015 10:57 am |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
I have to agree with Bigbend, that GT 1746 is worth investing in a surface drive rather than cutting the transom, although that will improve the performance...if you absolutely need a longtail motor if your area, sell the GT and get a short transom hull.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Tue Aug 25, 2015 5:12 pm |
Grant97
Thanks for all the help. I will probably just keep the boat the way it is this season and hopefully get a surface drive next season. Also, I am not sure what the rpms are when it is out of the water, but for a few weeks I had the long tail on a 1436 G3 and the rpms were fine. It would plane off 4 people, but with the gator-tail boat it won't. So I have a feeling it's not the prop, but instead the tall transom.
| Tue Aug 25, 2015 5:31 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
Transom is too high.
If you can deal with it, run it for this season and plan on buying a surface drive for the next season and leave the transom alone.
If not and you plan on leaving the longtail on it, take it to a fab shop and let them cut down the transom to whatever your motor manufacturer recommends.
Sent from my beeper
| Tue Aug 25, 2015 7:56 pm |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
If you didn't already have a longtail I'd say build a longer one with less of an angle. Like a 10° angle and 84"long
Sent from...wait, Where am I?
| Fri Aug 28, 2015 4:49 am |
