It is currently Sun May 11, 2025 12:51 am
Reply to topic  [ 29 posts ]
 Stuck prop
Post Stuck prop
I'm trying to get this old prop off and get my new prop on. Iv'e used half a can of WD40 with no luck. I tried heating in moderation with no luck. I've backed off the net closest to the seal housing thinking that may help but not so. My next idea is to use a pipe wrench on the blades. Any other ideas or trucks that have worked for you? Thanks.
Tue Sep 22, 2015 8:48 pm
Post Re: Stuck prop
36" pipe wrench open facing the prop. Jam up the shaft so it won't turn and then pull on it. Don't bounce or hit it. Just a steady hard pull and it should come loose.
-Custom pool noodle
-stage 4 water wings
Tue Sep 22, 2015 9:03 pm
Post Re: Stuck prop
Use a pipe wrench on the hub, as it can grab it without being on the blades. Put a crescent on the nut on the nut so it'll hold the shaft. May need a couple cheater pipes to get enough leverage.
Tue Sep 22, 2015 9:04 pm
Post Re: Stuck prop
Thanks for the replies. I have rebar wedged in the u joint so it won't spin.
Tue Sep 22, 2015 9:25 pm
Post Re: Stuck prop
WD-40 isn't what you need. Get some penetrating oil. Liquid Wrench, Knock'er Loose or what I like is PB Blaster. Soak it down early and often.
Use a long 2 x 4 with a hole drilled through it to fit over your shaft. Slide the 2 x 4 between your blade flukes and give it a spin. 5' to 6' board gives you a lot of leverage.
Good luck.
Tue Sep 22, 2015 10:05 pm
Post Re: Stuck prop
Oh....and Marine Grade Never Seize when you put it back on!
Tue Sep 22, 2015 10:06 pm
Post Re: Stuck prop
Fucking Junk
Wed Sep 23, 2015 1:13 am
Post Re: Stuck prop
Wed Sep 23, 2015 5:07 am
Post Re: Stuck prop
I made a 4' prop wrench out of 1.25"x1.25" square steel tubing (3/16" wall thickness) and couldn't get mine to budge.. and that was with Liquid Wrench (over a 2 wk period). Tried a torch as well. Ending up having to cut the prop off (needed replacement anyway).
How can liberals function with their heads shoved so far up their fucking asses???
Wed Sep 23, 2015 7:29 am
Post Re: Stuck prop
Thanks for the 2x4 idea and PB blaster I'll give that a try. As for marine grade anti seize, do auto stores carry that?
Wed Sep 23, 2015 7:56 am
Post Re: Stuck prop
Yep.
Wed Sep 23, 2015 8:03 am
Post Re: Stuck prop
I use an 18" pipe wrench with alot of elbow grease, it can sometimes be tricky to get the pipe wrench latched on there well. If your motor is on a boat strapping your tiller down to the floor of the boat also helps stabilize. Be careful using to much heat you'll ruin your seals. It will feel like its stuck and is not going to budge then it'll pop lose just got muscle it up real good.
40 Go Devil FNR on 20x48 WC Custom --
Wed Sep 23, 2015 8:30 am
Post Re: Stuck prop
Wed Sep 23, 2015 10:52 am
Post Re: Stuck prop
Wed Sep 23, 2015 11:14 am
Post Re: Stuck prop
The copper based is good for certain high heat applications. I personally don't use it on my engine. I use nickel based on engine components. I'd say why, but, I'm sure it would hijack the thread with a whole other debate.
Thu Sep 24, 2015 4:28 am
Post Re: Stuck prop
1854 Prodigy DPE Level 3 HDR
Thu Sep 24, 2015 5:01 am
Post Re: Stuck prop
Soak it with a 50/50 mix of ATF and acetone. Better penetrant than anything you can buy off of the shelf.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Thu Sep 24, 2015 6:29 am
Post Re: Stuck prop
Brake fluid and oil mix will do wonders give it 2-3 days
driving a gd in ur lake
and i aprove this message
Thu Sep 24, 2015 8:50 am
Post Re: Stuck prop
Thu Sep 24, 2015 9:36 am
Post Re: Stuck prop
Well low and behold the shaft had a crack in it... Prop is still on but shaft is junk at this point. :x
Thu Sep 24, 2015 4:28 pm
Post Re: Stuck prop
Better to find it now than to figure it out when your new prop is on the bottom of the river and you're calling SOS to a buddy ;)
-Custom pool noodle
Thu Sep 24, 2015 6:49 pm
Post Re: Stuck prop
That's what I told my self when I gave my card number to get a new shaft
Fri Sep 25, 2015 1:39 pm
Post Re: Stuck prop
What do you guy's use to stop the shaft from turning when trying to remove the prop?
Tue Oct 20, 2015 12:32 pm
Post Re: Stuck prop
Stick a piece of round bar through the u-joint
Tue Oct 20, 2015 4:50 pm
Post Re: Stuck prop
Wed Oct 21, 2015 6:51 am
Post Re: Stuck prop
Did you get that prop off yet? If you haven't, you may have to pull the shaft (if possible with the prop on) and put it in a vice. My brother's longtail prop was a SOB to get off . He ended up building a tool that slipped over the hub and between the blades to get enough torque on the prop to break it loose. But that doesnt answer how to keep the shaft from turning...sorry, not much help there.
Mon Oct 26, 2015 7:14 pm
Post Re: Stuck prop
I always used a old lawnmower blade an a cheater pipe of the 6' kind... an I put a stainless rod into the hole in the clutch where the shaft leaves the bottom of motor (prodrive)...
An always use never sieze, I keep mine in my boat along with the company issued 33, and tiewraps!
Let's Roll
Sun Nov 01, 2015 12:23 pm
Post Re: Stuck prop
Sent from my SAMSUNG-SM-G870A using Tapatalk
Wed Dec 09, 2015 8:13 pm
Post Re: Stuck prop
I bent my drive shaft on a 35 swomp ls. Pulled the shaft put into a vice and could not break the prop free. Talked to Jake from backwater and he sent me a video of cutting the jam nut with a angle grinder. Right before you get to the threads take a chisel to the nut and break it lose. Prop spun right off. Be careful not to damage the threads on the shaft if you plan on reusing it.
35 SWOMP(SOLD) 90 Merc tiller/1648 Lowe Jon(Heavily Modified Transom)mod v until I get an uncle J
Wed Feb 03, 2016 10:14 am
Users browsing this forum: No registered users and 97 guests
