It is currently Sun Apr 12, 2026 8:18 pm
Reply to topic  [ 18 posts ]
 Wiring killswitch predator 670
Post Wiring killswitch predator 670
So here I am wanting to get my killswitch on before I go hunting. I'm curious which wires are my "spark wires" and how to hook them up to the kill switch. Any help would be appreciated.
I believe that thing with the cooling fins on it is my ignition module/coil
Sat Nov 07, 2015 12:36 pm
Post Re: Wiring killswitch predator 670
I looked in my book and sadly there's no wiring diagram
The yellow wire is the low oil sensor. If I put the switch on that, will that kill it?
Sat Nov 07, 2015 12:38 pm
I'd just set it up to break the 12v supply to your key switch. Probably the easiest way to go about it without a wiring diagram. That way if the switch is yanked, it'll be just like turning the key off.
-Custom pool noodle
-stage 4 water wings
Sat Nov 07, 2015 12:40 pm
Okay. I'll try to finger this out
Sat Nov 07, 2015 12:41 pm
Ahhh who needs a kill switch anyways
Sun Nov 08, 2015 7:27 am
Sun Nov 08, 2015 9:11 pm
Sun Nov 08, 2015 9:17 pm
Good to know!!!
Sun Nov 08, 2015 10:20 pm
I appreciate your help
Sun Nov 08, 2015 10:21 pm
Tie a string to the key and that string to you. Easy lol
Sun Nov 08, 2015 11:31 pm
Always install your kill switch inline with the kill wired that ground your coils from the key switch. Or also inline with the Low oil sensor like DB8 said. That will instantly stop fire.
Mon Nov 09, 2015 9:59 am
I tried the low oil sensor. When I disconnected it the engine kept running
Mon Nov 09, 2015 10:02 am
For some reason I cannot see the pics, But you need to tap into the kill wire from the coils. It will run back to your key switch so find it and install kill switch there.
Mon Nov 09, 2015 10:20 am
Alright. Thank you
Mon Nov 09, 2015 10:47 am
For the kill switch typically any two across from each other are the ones you want to connect. You can test with a meter to verify. Set to continuity and test the leads and you should see Open loop then when you pull the kill switch you should see something reading resistance. (completes to ground). Looking at your pic I would follow the small gauge black wire to see if it goes to the coils, and that will be your tie in wire if so.
Mon Nov 09, 2015 11:37 am
Little update: I took my handy test light and went to wire searching. On the back of the ignition switch, the white wire is constant 12v, the yellow wire is on when you turn the key on and off when you turn it off. I tested both wires by starting the engine and disconnecting them. The yellow wire had a more "instant kill" so that is the one I used for the kill switch. If any ody wants pictures I can go take some later. I got kind of excited when I finally got it installed and working and forgot about the pictures. If you look at the first picture of the thread, the yellow wire I'm talking about is the one in that picture with the blue butt connector.
Sat Dec 12, 2015 9:49 am
Extreme Metal Fab 16x48 w/huntdeck
40EFI Backwater LT
Sat Sep 08, 2018 5:34 pm
He hasn't been around in a while. Probably not gonna be much help to you.
#TheGhostBoat
Sat Sep 08, 2018 8:35 pm
