It is currently Sat May 10, 2025 7:26 pm
Reply to topic  [ 12 posts ]
 Mud buddy hd - need advice
Post Mud buddy hd - need advice
Was cleaning my motor today and notice an opening on the out drive (beside the dipstick). I've never noticed if and am concerned a plug has fallen out? Any advice. 06 mud buddy hd 23hp
Sat Jan 02, 2016 6:31 pm
Post Re: Mud buddy hd - need advice
It's usually a 90 degree fitting, pointing downwards, to vent the heat. There should be a hose on the other side running up to the engine housing for the fan to shove air into the belt housing. Cools the belt and clutch a little with the air exchange
Sat Jan 02, 2016 7:51 pm
Sat Jan 02, 2016 8:07 pm
Yes
Sat Jan 02, 2016 8:13 pm
Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF
-Unbaffled VooDoo
-Gator Glide G2 with base
-Wet Sounds Stealth 10 Ultra V2
-Green LED Courtesy Lights
-15" Combo LED Light Bar
Sat Jan 02, 2016 8:22 pm
Thank your sirs.
Sat Jan 02, 2016 9:04 pm
I have an extra lying around here somewhere, if you need it.
Sun Jan 03, 2016 5:00 am
Sun Jan 03, 2016 9:19 am
It's not special. Just need something so water doesn't get in there, and air can still flow out freely.
Sun Jan 03, 2016 12:15 pm
Russ is correct it's a pvc plumbing 90 believe it would be either 3/4 or 1 inch. The name should be on the fitting, believe spear.
Sun Jan 03, 2016 5:37 pm
Wed Jan 20, 2016 5:33 am
Db, you are right I looked at it after I posted that. I just remember spear making plumbing connectors, they obviously make electrical aswell. Thanks for clearing that up
Thu Jan 21, 2016 12:10 am
Users browsing this forum: Google [Bot] and 170 guests
