It is currently Wed Sep 02, 2026 9:07 am
[ 5 posts ] |
No power in water 35 hp vanguard
Duck-killa
Joined: Sun Apr 08, 2012 10:48 pm Posts: 154 Location: Cut Off, LA
My buddy's 35 hp gatortail runs fine out of the water but when you put it in the water it won't get on the wave, it bogs down.It recently started doing this after we took the back off and changed the crankcase gasket. We changed the spark plugs, cleaned the carb, cleaned values and checked them, and checked the timing. Maybe the coils ? But I don't see how they would have went bad by just taking the crankcase off. Please help
_________________ Delta lvl 3 GTR with MAC 16x54 Gator hull
| Wed Jan 06, 2016 3:54 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: No power in water 35 hp vanguard
Pull the valve covers and make sure you're getting full travel in the valves.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Wed Jan 06, 2016 5:11 pm |
Russ
Had a Longtail that did this because air was getting into the fuel line at a loose clamp on a filter. Start with the easy stuff. Valve travel like Craig said, fuel delivery buttoned up tight, etc.
| Wed Jan 06, 2016 5:13 pm |
Buzz Killington
Might be coils...
Sent from my SGH-I317M using Tapatalk
B. MacDonald
| Wed Jan 06, 2016 6:20 pm |
Will C
Check cam lift as said above also ive seen the timing gears get out of time as the cover comes off. Did u double check the timing marks before puting cover back on?
| Wed Jan 06, 2016 9:00 pm |
[ 5 posts ] |
