It is currently Fri Apr 10, 2026 3:34 am
[ 10 posts ] |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 GTR Idle speed
What is a good average idle rpm for the 35. Mine tends to speed up gradually while in neutral. It will get up to 1400 rpm sometimes. I bump the throttle and it will drop to about 930. Thats about where Id like it to stay but it slowly speeds back up. Just curious.
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
| Thu Mar 04, 2010 7:23 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: GTR Idle speed
1100-1200 should be good.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Thu Mar 04, 2010 7:28 pm |
Tenpoint
 Re: GTR Idle speed
| Thu Mar 04, 2010 7:33 pm |
DMC
Joined: Sun Jan 25, 2009 7:23 pm Posts: 204 Location: Bayou House!
 Re: GTR Idle speed
Mine idles around 750-800 in gear with stock carb. Around 1000 in neutral.
| Thu Mar 04, 2010 8:41 pm |
MaXXis85
 Re: GTR Idle speed
Mine used to do that until I lowered the idle speed to 1150 and made sure my governer was set to 4250 then it idled great and consistant. Beofre the adjustments it would idle erraticly
| Thu Mar 04, 2010 9:14 pm |
Tenpoint
 Re: GTR Idle speed
| Fri Mar 05, 2010 6:46 pm |
DMC
 Re: GTR Idle speed
| Fri Mar 05, 2010 8:19 pm |
deltaduckmaster
 Re: GTR Idle speed
Ok set the gov. at what ever you wont wfo ou the water i say 4200 is good.. After you got that bend this little arm with the spring to get your idel perfect!! Fork the idel screw!!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
| Fri Mar 05, 2010 8:27 pm |
deltaduckmaster
 Re: GTR Idle speed
Ten i had to seach trough about 5 years worth of pics on my photobucket to find that pic so use it !!
| Fri Mar 05, 2010 8:31 pm |
Tenpoint
 Re: GTR Idle speed
| Sat Mar 06, 2010 7:10 am |
[ 10 posts ] |
