It is currently Sun Jul 13, 2025 7:58 am
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 Benelli 828u over under
Post Benelli 828u over under
Any of you fellows ever shouldered one? I'm seriously considering giving 2 house payments and my right testicle to own one. Biggest question I had was about the vent rib. In every photo I've seen it looks like a high vent rib, like all the sbe2's and M2's have. I've never seen a o/u with a high vent rib, they've all been flat. I have always said if somebody came out with a high rib o/u, I'd get one because you wouldn't have to readjust going from a semi Benelli to an o/u. Haven't seen one in a store around but there are plenty on gunborker.
HOTSAUCE170 wrote:
Sat Mar 12, 2016 2:39 pm
Post Re: Benelli 828u over under
Here is a high rib for you on a Blaser F3.
Sat Mar 12, 2016 2:54 pm
I have shouldered the Benelli O/U and thought it was ok at best. I am selling a few guns out of the safe to get my son a new competition gun. It is a FAIR Carrera Sporting model (made by Rizzini).http://www.fair.it/media/popup/carrera_ ... popup.html
Nicer than any gun I own, but my son could get some scholarship money through competitive sporting clays so it is worth the investment.
Sat Mar 12, 2016 2:59 pm
Ok, not interested in a lift kit for a vent rib. Not interested in another flat vent rib gun. What I want to know is if the Benelli o/u has a higher than flat stock vent rib so it points like a sbe2 or a m2.
Sat Mar 12, 2016 4:56 pm
If I recall it is very similar to the sbe. The high rib is typically added from a professional gun fitter.
Sat Mar 12, 2016 5:54 pm
Sat Mar 12, 2016 6:38 pm
Bass Pro usually has them. I was not super impressed. I liked the Browning much better.
Sat Mar 12, 2016 7:17 pm
If it points like a sbe2 I'll be impressed. Never shot an o/u that had that sight plane
Sat Mar 12, 2016 7:45 pm
I gotta stop by the sports center Monday and if they got one I'll check it out and let you know man
Sent from denda this
Sat Mar 12, 2016 9:22 pm
Looks like a normal sporter rib to me. Don't know how benelli cuts their stocks but if they're anything like their parent company, Beretta, all of their stocks will be cut the same and should shoulder the same. Doesn't mean they'll feel anything alike As the swing will be way different.
Also, just my 2¢, but for $3k you're getting into very nice shotgun territory. The Beretta Silver Pigeons are right in that range and, in my opinion, cannot be beat in that teir. Plenty of used, quality guns around there too. Might be worth shopping around.
Sat Mar 12, 2016 10:05 pm
FYI. A high rib is typical for a trap gun. Make sure it's for sporting clays or skeet.
Sat Mar 12, 2016 10:22 pm
I'm not referring to a high vent rib as in your typical trap type over under. What I mean (and what it looks like in the pictures) is a high vent rib like a semi auto sbe2, versus a flat vent rib like a maxis has. There's a little rise on the rib about 2 inches in front of the receiver that I haven't seen on any other o/u. I'm not interested in the beret tad because I know what kind of rib they have, and I'm not interested I the Benelli if they have the same rib, I've got another o/u already and don't want another one if the sight plane is flat. Check it out if they have one hotsauce!
Sun Mar 13, 2016 7:01 am
The rib height has alot to do with the engineering of the gun in regards to the combing or stock angle. After that it is just gun fitting.
Sun Mar 13, 2016 7:21 am
17/54 gator Trax 35 mudbuddy... mostly stock
Sun Mar 13, 2016 6:29 pm
Sun Mar 13, 2016 6:35 pm
Sun Mar 13, 2016 6:56 pm
Almost all o/u's are gonna have that step in the rib. It's to compensate for the barrels being on top of each other. Making the POI for both barrel the same. Which is also done in the casting/stamping/machining of the actual "stack" of the barrels as well. Your semi autos some have it and some dont, because cast and drop differences from model to model. Shotgunworld.com is a good resource for this kind of stuff. I used to be on there when I shot competetion sporting clays. Learned alot
Mon Mar 14, 2016 2:45 am
I beg to differ jake, I've owned and shot a bunch of user unders and none of them have that step in the rib. They are all flat vent rib guns. Brownings, beretta, Rugers, franchi......all of em. The shit you wrote above sounds smart and full of research, but it's not. You're dead wrong. Show me one that comes from the factory with an elevated vent rib in the brands named above
Mon Mar 14, 2016 3:43 am
Okay. My beretta silver pigeon does. I'll take a pic when I get home. On just about every gun it does, it's gradual instead of a solid step. The cheaper ones use a solid step. Look at this picture and you can see it
My point is is doesn't necessarily matter what it looks like one way or another the gun makers have to adjust the angle of your line of site vs the angle of the barrels to get the POI as close as possible for both barrels.. I know and you can research it for yourself, but you wrong right now
Mon Mar 14, 2016 6:09 am
1754 XSeries Kawi Powered PRODRIVE ...
Mon Mar 14, 2016 7:04 am
Mon Mar 14, 2016 7:12 am
I don't know why this is so hard to understand. When you have a gun shimmed to set up like most American made shotguns, there are 2 types of vent ribs. The elevated ones (sbe2, m2) and the flat ones (like the montefeltro or the maxus). Every o/u I've ever shot has a fucking flat vent rib. That's a fact. It may have a little rise but it's called a flat vent rib and it gives you the perception of a flat sight plane for upland shooting. When you put the gun to your shoulder and look down the sight plane the rib is the same level as the receiver. I don't give a shit about cast, camber, blah blah blah. All I want to know is does benelli make an o/u with an elevated vent rib, unlike the flat ones that beretta, ruger, browning, franchi, Tristar, and cz have. And Buddy, you're correct. Geez it's like herding fucking cats here.
Mon Mar 14, 2016 7:17 am
Mon Mar 14, 2016 7:24 am
Well quit drinking at 930 in the am est, maybe it will make sense
Mon Mar 14, 2016 7:25 am
So No, the 828u does not meet your definition of a flat rib. It has a visible step
Depending on how the stock is you may see it In the sight plane, you may not. I guess it just depends on you big your head is and how fat your cheeks are and how wide your jaw is and if you shoot with your gun high or low on your shoulder
Mon Mar 14, 2016 7:37 am
Big head. ...check. big cheeks....neg. wide jaw....I would say medium width.
Mon Mar 14, 2016 8:27 am
I looked at an 828 for you today and took the best pics I could. I shouldered the 828 and an M2 together and the rib on the M2 seemed a little higher in my sight plane than the 828. The rib on the 828 was noticeably higher than the receiver and sighted very similar to the M2 but I could tell a difference between them. All that being said I just shouldered them both in the store and didn't study them intensely and I'm sure that shooting them side by side will be the true test. The 828 seemed like a well put together gun and felt light for an o/u but swung nice and had a balance to it that was different to me but im no benelli guy so take that into consideration. Overall I felt benelli was attempting to make the 828 feel like their popular autos and that's what you were asking I hope.
Mon Mar 14, 2016 12:10 pm
Hotsauce you are my hero! You took what I was asking for what it was worth and told me exactly what I needed to know, and a fucking pic of the sight plane to boot! Thanks brother
Mon Mar 14, 2016 12:40 pm
no problem jb
Mon Mar 14, 2016 1:18 pm
Hotsauce what was the price on that gun? I ordered one off gunbroker, hope I got a better deal than they have down there in perry
Tue Mar 15, 2016 12:28 pm
1854 Prodigy DPE Level 3 HDR
Tue Mar 15, 2016 12:55 pm
I can't see how with the price I found. About 450 lower than msrp, free shipping.
Tue Mar 15, 2016 1:53 pm
hey jb that gun was real shiny when I looked at it. If you want I'll rough it up and spray paint for a half gallon of Evan williams so you can hunt with it.
Tue Mar 15, 2016 1:59 pm
Tue Mar 15, 2016 2:15 pm
Tue Mar 15, 2016 2:17 pm
Tue Mar 15, 2016 2:27 pm
Evan Williams green label and natural light...the preferred drink of kings!
Tue Mar 15, 2016 3:39 pm
Kings of the homeless campsite?
Tue Mar 15, 2016 9:11 pm
No, cb. You're confusing natty light with the miller high life.
Tue Mar 15, 2016 9:22 pm
Wed Mar 16, 2016 12:01 am
Users browsing this forum: No registered users and 87 guests
