It is currently Wed Apr 01, 2026 2:59 pm
Reply to topic  [ 9 posts ]
 Not getting speed i should from longtail
Post Not getting speed i should from longtail
I have a homemade backwater clone longtail. I made it and have used it for 2 seasons. It runs a 13hp predator. I was using it on my 1648 and was getting about 10mph with me and another person. I decided to put it on my newer 1236 crestliner jon, with float pods made by backwater. I cant seem to get over 10mph. Same speed as when on my 1648. Should it not go faster on my 12 foot. Thanks
Tue Mar 22, 2016 7:04 pm
Post Re: Not getting speed i should from longtail
Smaller boat is prob sitting deeper in water.
Wed Mar 23, 2016 8:14 am
With the pods, its sitting normal. i was expecting 15mph
Wed Mar 23, 2016 8:44 am
If you're getting the same speeds on a heavier and lighter boat, may be a prop issue.
Rpm different on the different boats?
Wed Mar 23, 2016 9:07 am
I have a 8x4 backwater prop. Same used on both boats. The only difference between the 2 boats besides size is transom height. The transom on my 1236 is An inch higher than on the 1648. I am having a little trouble with the cavitaion plate angle. It was perfect on the 1648, but now the prop is all the way in the water on the 1236. I have the backwater cav plate
Wed Mar 23, 2016 9:39 am
The prop should be in the water. Its not a surface piercing prop. The cav plate should be just under the water and not pulling the prop down or pulling it out of the water. You'll get better speeds if the prop isn't making bubbles chopping the surface
Screen shot of a video from backwater. Notice you don't see the cav plate when on plane.
Wed Mar 23, 2016 10:30 am
Got my speed issues fixed. Once i got cav plate set right, and did a carb rejet i went from a top speed of 8mph to 17mph.
Tue Mar 29, 2016 4:34 pm
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Tue Mar 29, 2016 9:26 pm
Huck is exactly right.
Wed Mar 30, 2016 6:12 pm
