It is currently Mon Apr 13, 2026 4:47 am
Reply to topic  [ 12 posts ]
 29hp Mud buddy Top Bearing
Post 29hp Mud buddy Top Bearing
I have a 29hp Mudbuddy Longtail I just replaced both Top Bearing and bottom and seals on the shaft Before I changed it and the top Bearing was really hot couldnt even keep your hand on itand grease wouldkinda of come out so I decieved to change which was true the breaing had issues but Does anyone know how hot that top bearing and seal get ? Temp ? Or does it really runs that hot ? I know its getting some heat fro the motor shaft to
Wed Jul 13, 2016 4:21 pm
Post Re: 29hp Mud buddy Top Bearing
My beavertail upper bearing runs hot too. You can't hold your hand on it after a long run.
Wed Jul 13, 2016 8:03 pm
You can say that again
Wed Jul 13, 2016 8:25 pm
Thu Jul 14, 2016 10:49 am
I understand a bearing running a little warm. However, Hot. Not so much. Hot comes with being too tight and hence high internal friction or from inadequate lubrication. Stiff grease will run hotter that lighter grease - lubrication. Have you tried light gear oil to see? Bearings are fussy and the mounting dimensions and tolerances are fussy too. Too tight of a fit of either the inner shaft tolerances or the outer pocket tolerances will tighten internal dimensions in the bearing and cause - heat.
Mark F. Cheney
on the Great Salt Lake marsh
Sat Jul 16, 2016 9:16 am
I also run a MBLT 29hp.... That upper bearing stays hot.....
Tue Aug 02, 2016 7:42 am
Tue Aug 02, 2016 7:45 am
With a Temp Gun Im running between 175 degs to 189ish Degs. That is running at 3400 to 3600 RPM Doing like 19 - 20 Mph Can some one check there while there running and feed back would really be appreciated I just want to make sure Im ok New Seal ,Bearings and Drive Shaft. Mud Buddy Said to losing up the Set Screws on the motor side and run it like that to make sure the U joint gets the sweet spot I have it looks like in improved which before was 190degs to 220 when I first did all the new things. BUt it is still really hot to the touch tho
Thu Aug 11, 2016 7:20 pm
Take out the spark plugs, grab your prop and try to turn it. If you feel a lot of torque there is still a bind somewhere. My guess is still the U joint isn't set right.
Once you get it right, try to remember to mark the shaft(s) on each side of the U Joint with a Sharpie before you disassemble.
Sun Aug 14, 2016 5:36 am
Had a hot upper bushing with a GDLT. Turned out the shaft tube was bent. Had to put it up against a tree and beat it with hammer to get it back straight. That was actually how coco told me to fix it.
Sun Aug 14, 2016 7:09 am
