It is currently Wed Apr 01, 2026 3:58 am
Reply to topic  [ 3 posts ]
 Longtail Throttle Lever
Post Longtail Throttle Lever
Just acquired a Long Tail and the Handle on it is bigger then most around 4" in Diameter. Anyone been able to put a throttle lever like a dirtbike clutch on anything bigger the 7/8 or 1"?
Thanks
Wed Sep 21, 2016 8:13 am
Post Re: Longtail Throttle Lever
Turn a sleeve to fit the ID of your tiller and 7/8" ID. I make them 2" long and then put a 7/8" x 8" long piece of tubing in the collar. I secure it all together with 2 3/16" stainless pop rivets. works great. I use BMX bike brake handles. Some have longer throw than others. compare them a bit before you buy one. The BMX brake cable works well for the inner cable and I use a poly lined outer housing from the Go Kart world, Asuza is a good distributor source for this.
on the Great Salt Lake marsh
Wed Sep 21, 2016 6:24 pm
Any Pictures? And thanks for the info
Thu Sep 22, 2016 8:02 am
