It is currently Wed Dec 24, 2025 9:11 pm
Reply to topic  [ 12 posts ]
 Bigger Prodrive Trim Roller Installation
Post Bigger Prodrive Trim Roller Installation
I ordered the bigger roller that wraps around my current roller on the bottom of the trim arms. I couldn't get it to roll over the current roller with everything still connected because I didn't have enough space between the roller and tower housing. So I took it all apart and got the bigger roller on the trim arm, but now I can't get the trim arms lined up with the hole in the housing. The two bars at the top are stopping it from going far enough. I think I have the newest version of the larger top yoke that connects to the ram. It has two holes drilled in it facing the ram to allow slightly higher trim. I don't know what else I could need.
Does anyone know how this is supposed to work? It just doesn't seem like it will fit without bending or removing the two bars that protect the engine from the trim arm.
Sun Jul 29, 2012 5:48 pm
Post Re: Bigger Prodrive Trim Roller Installation
Sounds as if your at the limit of the trim. If you need more your going to have to shim at the transom.
Tue Jul 31, 2012 7:31 am
pm med. He just installed one.
HOTSAUCE170 wrote:
Tue Jul 31, 2012 6:44 pm
I never had that prob. Mine came n 2 pieces. Put them around the roller and put straps in the grooves.
Tue Jul 31, 2012 7:42 pm
1850 & 36pd
Tue Jul 31, 2012 9:29 pm
Anyone know if one of those peices that make your trim roller bigger still work on one with the hydro trim ? My boat transom is little to steep
Sat Aug 27, 2016 11:25 am
Mine didn't work with the hydro
Sat Aug 27, 2016 11:47 am
post a pic of what your talking about. I had to make some changes to my hydro trim and may have done what your talking about.
Thu Sep 01, 2016 4:47 am
Anyone know what angle transom is supposed to be for a Prodrive to run correctly ?
Thu Sep 01, 2016 10:46 am
I think it's either 15 or 16 degrees.
Fri Sep 02, 2016 6:12 am
Fri Sep 23, 2016 9:31 pm
Sat Sep 24, 2016 5:47 am
