It is currently Sat May 10, 2025 3:47 am
Reply to topic  [ 11 posts ]
 PD LU parts list diagram needed
Post PD LU parts list diagram needed
I recently bought a lower PD unit for the reverse plate. The gears on the LU are garbage, I was looking at rebuilding it and throwing a motor on it but was looking for a diagram or some sort of parts list so I can put it back together since I wasn't the one who took it apart. Thanks.
Tue Oct 18, 2016 8:02 am
Post Re: PD LU parts list diagram needed
what year, some parts are different depending on the year
Tue Oct 18, 2016 8:33 am
Sorry its a 09
Tue Oct 18, 2016 9:12 am
I think you have the older lower like mine. I have an 07 that has the gear oil lower. If I remember, 2010 changed to the grease filled lower which can be bought to replace the oil filled for about $260 if I remember. I'll try and find my lower unit schematic, but if I can't, Peck sent it to me. You can contact them and they'll send you the correct one.
Tue Oct 18, 2016 10:46 am
call pd, i'm sure they would help u after calling their stuff garbage.
Tue Oct 18, 2016 4:14 pm
Tue Oct 18, 2016 5:43 pm
^^^that
I don't think he was talking bad about pd.
Tue Oct 18, 2016 5:54 pm
If PD was garbage I wouldn't buy this lower for the reverse plate to put on my other PD..... The gears on the shafts are tost, no good, broke.....
Tue Oct 18, 2016 6:48 pm
I can't seem to find my diagram. Just give them a call and they'll email it to you. While your at it, get them to email you the wiring diagram. If the gears are toast, might want to check all the "possible" dry rotted wiring. I ended rewiring mine and used a waterproof automotive connector.
Wed Oct 19, 2016 4:17 am
Will do, thanks banded!
Wed Oct 19, 2016 8:31 am
Tue Oct 25, 2016 9:13 am
Users browsing this forum: No registered users and 144 guests
