It is currently Sat Nov 07, 2026 7:48 pm
Reply to topic  [ 7 posts ]
 BELT TENSION QUESTION
Post BELT TENSION QUESTION
BELT TENSION QUESTION:
I put a new belt on and tensioned it to 20lbs since that's the requirement on Mudbuddy motors. I ran it on the water for for about 20 mins. Now the belt has stretched a little and tension is at 15 lbs. The question is, do I now just retention it to 16lbs and keep it there or should I go a little tighter since it's still new?
18x44 Gator Trax, Stage 2 Mudbuddy
Sun Oct 23, 2016 1:00 pm
Post Re: BELT TENSION QUESTION
Run it. When it drops below 13, tighten it to 16, check it for a couple hours, then you should be good to go.
Sun Oct 23, 2016 5:17 pm
Got it Russ thanks.
One more question. I put a new clutch on and used red Loctite and torque the clutch bolt to 55 foot lbs. Is that good or should I go a little less? I saw gator Trax video where they recommended 55 foot pounds, but also saw some specs on here where someone said 50 ft pounds. It's a 2006 Mudbuddy. Not the new HDR model
Sun Oct 23, 2016 6:55 pm
55.
Sun Oct 23, 2016 9:44 pm
Roger that
Sun Oct 23, 2016 10:27 pm
Learn to follow
Mon Oct 24, 2016 5:16 am
Mon Oct 24, 2016 4:00 pm
