It is currently Thu Apr 09, 2026 9:12 am
Reply to topic  [ 21 posts ]
 Backwater 35hp
Post Backwater 35hp
I have finally decided to buy a backwater 35hp long tail. i decided to go with a long tail motor because the salt marsh that I'll be using the boat in has a lot of sand bars & a few mud flats but the mud is hard enough to walk on. My question is what size boat would be best. I'll have myself & 2 guys (200,200,200 lbs)at most in the boat at one time. Most of the time it will be just me. I have herd long tails work better on long skinny boats. Would a 1836 draft to much and bottom out on a sand bar. I've read in a couple of post that some of you use a war eagle 1648 but being a mini vee bottom boat would it be hard to push it off a sand bar if I did get stuck. I know a war eagle is lighter than a true mud hull. the biggest wave I will see is 2ft but that is very rare. It would be nice to go 20mph with just me & 15mph with 3 people. So what boat do think
Sat Nov 26, 2016 9:23 am
Post Re: Backwater 35hp
20x40 or 20x44 would be the ticket in the marsh with a big block longtail. 18x44 would do well too.
-Custom pool noodle
-stage 4 water wings
Sat Nov 26, 2016 10:15 am
What he said. 48 would be fine too with that engine.
Sat Nov 26, 2016 10:26 am
I've got one on an 18/48. Pushes my two boys and I just fine.
Sat Nov 26, 2016 11:07 am
Thanks for the replys. It sounds like 1844 or 1848.
Sat Nov 26, 2016 10:15 pm
Only thing I would counsel is to go custom...for what you pay for a WE, you can probably get a custom flat hull just like you want!
Sun Nov 27, 2016 6:17 am
I'm running the 35 on a 1852. Ran it on a 1748 also. Runs better with load on the larger boat!
Wed Nov 30, 2016 9:28 am
18x44 is the ticket... that's what I run.... big enough for 3 guys and gear, narrow enough to get in tight spots..... long enough to spread out weight.... I'm running a 29hp MBLT, empty speed is 18-19mph.... loaded down I run 17-18mph.....
Thu Dec 01, 2016 4:18 am
Good rig! Ninja, is that a 29 Kawasaki?
Thu Dec 01, 2016 7:24 am
That is a really nice setup you have there ninja. Do you think the 1844 go devil boat be better than a 2044 go devil boat?
Fri Dec 02, 2016 3:00 pm
Glades, no radiator. Not the kawa.
Fri Dec 02, 2016 3:46 pm
Ok, could not see front of motor, I suspected it was a Vanguard. Good speed considering that hull is not lightweight.
Fri Dec 02, 2016 7:57 pm
do you think i could put the backwater 35hp on a 1848 gatortail boat? or do you think it would be better to put it on a 1844 go devil boat? the gatortail boat has a 21 inch transom & a 20 degree angle i would have to get the 71ls
Thu Dec 08, 2016 8:08 am
It'll be good on either, I would prefer the 48 myself.
Thu Dec 08, 2016 9:20 am
You won't like it on a 21 inch transom.
Fri Dec 09, 2016 7:48 am
Fri Dec 09, 2016 11:55 am
Fri Dec 09, 2016 3:06 pm
Profile YIM
Not secondhand here. I did it, with pretty decent results. Weldbilt hull with 20" transom and a 72" MudBuddy Longtail.... Boat ran 20 light, with no issues blowing out, turning or fighting the tiller.
-Custom pool noodle
Fri Dec 09, 2016 9:23 pm
Same here. I ran my Backwater LS on a 17ft mod V Lowe with a 20 inch transom. I had to fight with it but I could get around. I put that motor on an 18/48 with an 18 inch transom and its just fine.
Sat Dec 10, 2016 7:00 am
Sat Dec 24, 2016 3:40 am
Sat Dec 24, 2016 3:41 am
