fireman1562003
Joined: Tue Jan 31, 2017 10:43 am Posts: 67 Location: Wylie Tx
 BB tearing up motor
whats this I hear that a BB with vibrate so bad and tear your motor up and cause lower unit to crack ?
_________________ 1754 UNCLE J 37EFI GTR stage 2 Delta ,
Fri Feb 24, 2017 10:41 am |
TPerkins
Joined: Wed Jan 02, 2013 12:59 pm Posts: 1793 Location: Clear Lake, Tx
 Re: BB tearing up motor
I would think anybody with any kind of sense would realise the prop is off balance far before it gets bad enough to cause damage to the LU.
Sent from my SM-G930V using Tapatalk
Fri Feb 24, 2017 10:44 am |
Will C
Some of them do vibrate like a sumbitch. I cant comment on them hurting parts or not. Ive ran some that were clean with little vibration. One of the worst ones on a gtr was WAY bad. I checked weight and pitch for balance and its was dead on. I cant explain why some are worse than others
Fri Feb 24, 2017 10:48 am |
fireman1562003
yea mine don't seem to vibrate any worse then the stock 3 blade .
im with though you should be able to tell something is wrong way before you tear it up
Fri Feb 24, 2017 10:49 am |
TPerkins
But when they do this it's a whole nother story.
Fri Feb 24, 2017 10:51 am |
fireman1562003
yea that's not good !! keep extra prop in boat
Fri Feb 24, 2017 10:52 am |
BlueShamu
Vibration in these motors will wreck some stuff....and it's not limited to any one particular prop manufacturer.
You get prop wear, you get out of balance. Out of balance causes vibration. Vibration causes fatigue. Fatigue leads to failure....somewhere. Depending on the brand motor will dictate where it fails.
Fri Feb 24, 2017 6:56 pm |
TPerkins
I've seen a pile of big blades broken identical to the one I posted.
Fri Feb 24, 2017 8:45 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
I got one that looks just like that one! Had less than 20 hrs.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Sat Feb 25, 2017 8:50 am |
Quack N Stack
Joined: Sat Dec 15, 2012 9:43 pm Posts: 2225 Location: Baytown, Tejas
It dont matter what prop you got, if it breaks or goes to far outa balance you shit outa luck anyway...IMG_1024.JPGIMG_1025.JPGIMG_1026.JPG
Tue Feb 28, 2017 6:14 pm |
CypressCritter
How hours on the motor and prop? Is that something that will happen often to the cast lower housing?
Wed Mar 01, 2017 9:24 am |
Quack N Stack
Wed Mar 01, 2017 10:43 am |
caddobrook
Wed Mar 01, 2017 11:01 am |
Quack N Stack
Wed Mar 01, 2017 12:40 pm |
