It is currently Mon Dec 15, 2025 1:46 pm
Reply to topic  [ 6 posts ]
 Bad zert?
Post Bad zert?
Do zerts go bad? Greased my HDR shaft a couple of days ago. Let the excess bleed out. Ran some this weekend and then noticed this. Also, does it look like water is mixed with the grease? Will replacing the fitting likely fix this? It feels like it's screwed in tight and the grease seemed to have come out the top.
Mon Mar 27, 2017 9:31 am
Post Re: Bad zert?
Sometimes the ball will stick down and allow grease out the tip. Did you grease it the proper way by removing the screw in the outdrive casting and removing the nut on the prop end of the shaft? You may have over greased it and had to much pressure in the outdrive tube? If you do that to many times you'll blow the seals out both ends and have a damn mess in the belt box.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Mar 27, 2017 10:06 am
Post Re: Bad zert?
I removed the upper screw to vent it but not the prop nut
Mon Mar 27, 2017 11:23 am
Post Re: Bad zert?
Did you let the motor run while in gear for a bit after greasing with the screw out? It will work out a bit of the grease if you over filled it. Most tend to over fill while greasing, that's why I ask.
1854 Prodigy Open
HDR/Stage 3 mods
Tue Mar 28, 2017 4:34 am
Post Re: Bad zert?
1854 Prodigy Open
HDR/Stage 3 mods
Post Re: Bad zert?
Bad zert! Cheap easy fix. A zert should not let grease come out of it. Be sure when greasing, wipe off zert and grease gun tip to clean it of foreign material. That could also keep the little ball from sealing off after greasing. Just takes 1 little grain of sand and leaky-leaky.
Tue Mar 28, 2017 8:03 am
