It is currently Sat Jun 08, 2024 1:25 pm
Reply to topic  [ 14 posts ]
 Exhaust manifold bolts gone..
Post Exhaust manifold bolts gone..
So my Briggs EFI vibrated both bolts out of the exhaust on the right hand sod. Has anyone us d Stage 8 fasteners on a Briggs? Stage 8 (not grade 8) works great on hot rod exhausts.
Tue Jul 10, 2018 12:28 pm
Post Re: Exhaust manifold bolts gone..
180" pounds is the Torque spec on the bolts. One main contributor to bolts backing out is an unbalanced propeller. You would be surprised at some New in box propellers are out of balance.
Wed Jul 11, 2018 6:34 am
Stage 8 bolts
Wed Jul 11, 2018 6:39 am
Check your prop and make sure the bolts stay tight after you correct the torque. I haven't seen a need for locking fasteners. proper torque is fine.
Wed Jul 11, 2018 6:44 am
I use these, no problems
Wed Jul 11, 2018 11:36 pm
Couldn't get pics to load on mmt anymore so had to get tapatalk. The pics are a little bigger than normal, lol
Wed Jul 11, 2018 11:50 pm
The only thing that sucks about a stainless bolt.... Is when it breaks/ galls inside the head....BRUH its hard as a MFER to get out..
Thu Jul 12, 2018 5:41 am
Why not install studs and use locking nuts ? Never had one come loose again.
Thu Jul 12, 2018 6:03 am
Thu Jul 12, 2018 9:20 am
I keep extra bolts in the boat. I always neverseize the heck out of the bolts when I put them on.
I go through at least one muffler a year, most years 2. stock mufflers suck.
vibrations from out of balance props or something amiss in your driveline will cause all kinds of things to shake loose/break.
if u have axcess to those fancy bolts, use them and let us know how they do.
Sat Jul 14, 2018 1:10 pm
I need to order some bolts for my exhaust too. What size are they?
Thu Aug 02, 2018 11:14 am
8 x 1.25 metric thread
Thu Aug 02, 2018 12:01 pm
Fri Aug 03, 2018 8:23 pm
Mon Aug 06, 2018 5:24 am
Users browsing this forum: Google [Bot] and 238 guests
