It is currently Fri Jun 27, 2025 6:36 am
Second trim switch on grab handle
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: Second trim switch on grab handle
Sat Jun 14, 2014 8:48 pm |
bdavis85
So its as easy as replacing the stock switch with a non reversing one and adding a new one?
_________________ 1848 Prodigy with stage 1 35 GTR BPS Pro Staff
Wed Jun 18, 2014 7:08 am |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Wed Jun 18, 2014 7:16 am |
bdavis85
Let me know how it goes. I am very interested but want to make sure I get the right parts and don't have to buy them twice.
Wed Jun 18, 2014 7:39 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
ok when u remove the stock switch from the system u will have to use either relays or a solenoid cause any other little switch u use will not be able to handle the load ! the reason the stock switch can handle the load without any relays or solenoid is cause it has big solid copper poles in it witch is good for 70 amps
Thu Jun 19, 2014 6:09 am |
12ga
For those running the reversing contactor, what gauge wire are you using and where are you mounting it? Close to the battery, on the transome under the motor, on the motor itself? My battery sits under the middle set in my boat so I was going to run some 8 ga.from the battery and Mont the contactor on my transome. Should I mount it closer to the battery and not worry about the heavy wire, or what?
Mon Jun 23, 2014 7:45 am |
bayouboy
I used 10ga for the battery/ trim/ contactor hook up . I've hooked them up on the motor, battery box, and under the back corner brace.
Mon Jun 23, 2014 1:45 pm |
cj
I know it's a old post. But why not use two diodes in line. And still be able to use stock trim switch. The diodes would keep power going from the second switch up to the stock switch. And yes I understand you would use the reversing switch. To make it work.
Mon Nov 02, 2015 9:04 pm |
Users browsing this forum: No registered users and 230 guests |
