It is currently Fri Aug 01, 2025 7:19 am
Reply to topic  [ 10 posts ]
 GTR Idle speed
Post GTR Idle speed
What is a good average idle rpm for the 35. Mine tends to speed up gradually while in neutral. It will get up to 1400 rpm sometimes. I bump the throttle and it will drop to about 930. Thats about where Id like it to stay but it slowly speeds back up. Just curious.
Thu Mar 04, 2010 7:23 pm
Post Re: GTR Idle speed
1100-1200 should be good.
Thu Mar 04, 2010 7:28 pm
Thu Mar 04, 2010 7:33 pm
Mine idles around 750-800 in gear with stock carb. Around 1000 in neutral.
Thu Mar 04, 2010 8:41 pm
Mine used to do that until I lowered the idle speed to 1150 and made sure my governer was set to 4250 then it idled great and consistant. Beofre the adjustments it would idle erraticly
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Mar 04, 2010 9:14 pm
Fri Mar 05, 2010 6:46 pm
Fri Mar 05, 2010 8:19 pm
Ok set the gov. at what ever you wont wfo ou the water i say 4200 is good.. After you got that bend this little arm with the spring to get your idel perfect!! Fork the idel screw!!
17x48 extreme stage 2 GTR
Fri Mar 05, 2010 8:27 pm
Ten i had to seach trough about 5 years worth of pics on my photobucket to find that pic so use it !! :lol:
Fri Mar 05, 2010 8:31 pm
Sat Mar 06, 2010 7:10 am
Users browsing this forum: No registered users and 84 guests
