It is currently Sat Aug 02, 2025 3:49 am
[ 10 posts ] |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 GTR Idle speed
What is a good average idle rpm for the 35. Mine tends to speed up gradually while in neutral. It will get up to 1400 rpm sometimes. I bump the throttle and it will drop to about 930. Thats about where Id like it to stay but it slowly speeds back up. Just curious.
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Thu Mar 04, 2010 7:23 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: GTR Idle speed
1100-1200 should be good.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Thu Mar 04, 2010 7:28 pm |
Tenpoint
 Re: GTR Idle speed
Thu Mar 04, 2010 7:33 pm |
DMC
Joined: Sun Jan 25, 2009 7:23 pm Posts: 204 Location: Bayou House!
 Re: GTR Idle speed
Mine idles around 750-800 in gear with stock carb. Around 1000 in neutral.
Thu Mar 04, 2010 8:41 pm |
MaXXis85
 Re: GTR Idle speed
Mine used to do that until I lowered the idle speed to 1150 and made sure my governer was set to 4250 then it idled great and consistant. Beofre the adjustments it would idle erraticly
Thu Mar 04, 2010 9:14 pm |
Tenpoint
 Re: GTR Idle speed
Fri Mar 05, 2010 6:46 pm |
DMC
 Re: GTR Idle speed
Fri Mar 05, 2010 8:19 pm |
deltaduckmaster
 Re: GTR Idle speed
Ok set the gov. at what ever you wont wfo ou the water i say 4200 is good.. After you got that bend this little arm with the spring to get your idel perfect!! Fork the idel screw!!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Fri Mar 05, 2010 8:27 pm |
deltaduckmaster
 Re: GTR Idle speed
Ten i had to seach trough about 5 years worth of pics on my photobucket to find that pic so use it !!
Fri Mar 05, 2010 8:31 pm |
Tenpoint
 Re: GTR Idle speed
Sat Mar 06, 2010 7:10 am |
[ 10 posts ] |
Users browsing this forum: No registered users and 92 guests |
