It is currently Sat Dec 20, 2025 3:03 pm
Help U of F Research student create the Ideal rig
zingler1
 Re: Help U of F Research student create the Ideal rig
As is with all forums. Last question alumacraft boats 1 piece welded made in the 1980's what grade aluminum was used? would they be heavier than newer models? Are they tougher than newer models?
| Tue Nov 16, 2010 2:05 am |
cb5331
I would guess .080 or .100 aluminum. A lot of newer models have bracing running lengthways in the boat instead of horizontal which helps to prevent hooks, also a lot have .125 aluminum. If you can get the hull id off the boat, you can call the manufacture and check to see how thick the hull is... A lot of time's it is stamped right next to the hull id xxxxxxx080, xxxxxxxx100, or xxxxxxx125, etc...
| Tue Nov 16, 2010 9:22 am |
Woodiebuster
| Tue Nov 16, 2010 7:59 pm |
mississippiduckboy
_________________ 14 by 44 Weld Craft powered by a 20hp. go devil longtail Team Arc Angel Bowfishing
| Tue Nov 16, 2010 8:23 pm |
