It is currently Mon Jul 28, 2025 6:48 am
Reply to topic  [ 13 posts ]
 treated 2 by for trailer runners
Post treated 2 by for trailer runners
Is there any reason I can't just put treated 2x4 or 2x6 flat on my trailer with no carpet for runners. I want to put them on the trailer without the brackets so the boat will be lower on the trailer. Also, I read somewhere that treated lumber had something in them that would attack the aluminum. Any thoughts on this?
Wed Oct 27, 2010 7:51 am
Post Re: treated 2 by for trailer runners
I got radical with mine when I redid the boards. I went with 4X4 treated posts. I figured the extra weight on the trailer was not a killer, and i wanted to be done with it. If you go look at Lowe's or any lumber yard the price differences on a few boards is nothing to think too much about either.
I got frogspit on my boat, and i did not put carpet back.
Wed Oct 27, 2010 10:31 am
Those new AQ2 (or whatever) the new treatment is is really hard on alot of different metals as well as semi corrosive.
I'd go with the new composite type lumber. Your boat will slide on and off easier, don't have to worry about rot, splitting, or cracking
Running an 1860 Gator Tail Extreme with a 25 Horse Merc
Wed Oct 27, 2010 1:06 pm
Don't use the new ACQ treated lumber. It will eat through the aluminum..
Wed Oct 27, 2010 6:35 pm
Wed Oct 27, 2010 7:08 pm
I am running just 4 2x6's on the bottom with counter sunk screws and no carpet and they work great.
Wed Oct 27, 2010 8:14 pm
the carpet is what causes the electrolisis probs on aluminum boats,not the wood. :lol:
Thu Oct 28, 2010 12:47 am
Do like you're talkin about with just the bare wood, then put the teflon strips on top of it. It'll slide on & off easier, plus the wood will not be in contact with the metal.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Oct 28, 2010 6:56 pm
I would not use any type of treated wood, especially ACQ type. It will quickly corrode an aluminum hull. Use in saltwater will make it happen even faster. I have proof if anyone would like to see the results. Carpet has no effect on the aluminum. Check out the web site Ultimatebunks.com
:evil:
Fri Oct 29, 2010 7:29 am
i used treated 2x4's wrapped in carpet and topped the off with guide silkes i found at bass pro. i run a heavy plywood/ fiberglass boat and don't have any problems out of that combo.
Fri Oct 29, 2010 10:22 am
Why not just use a regular spruce 2x and seal it then carpet it? Should last as long as you need it to..
Fri Oct 29, 2010 6:46 pm
Poker is running the 2x6's as well
"Gofer Everette?"
Sat Oct 30, 2010 3:40 am
Profile YIM WWW
Poker and Gator running untreated 2x6's? They are cheap and I guess would last a little while.
Wed Nov 03, 2010 9:47 pm
Users browsing this forum: No registered users and 113 guests
