It is currently Mon Jul 21, 2025 4:08 am
Reply to topic  [ 9 posts ]
 Prodrive prop removal
Post Prodrive prop removal
so I've started to attemp to take my prop off. I'm already searched, and read as much as could. I've located the stop and I'm using the 3/16 rachet extension. To get the prop off I'm using a trucker breaker bar. It catches both blades and is about 2-2.5 ft. I was putting so much force on it it looked like I was deflecting the shaft. Still the prop didn't budge. Do I need more leverage?
Thu May 30, 2013 4:50 am
Post Re: Prodrive prop removal
Get a 6-7ft 2x4 and put a hole big enough to fit over the prop nut about 12" from the end of the board and try it again
1850 & 36pd
Thu May 30, 2013 5:02 am
I had to heat mine up last time only because the previous owner didn't know what never seize is. If you have to go that route just keep the heat away from the seal.
1648 gd hull flying in front of a stage 3 with fpr
Thu May 30, 2013 5:08 am
Take mine off with a 3' crow bar. Can't stand the threaded prop, they're finally going to change that soon...
Thu May 30, 2013 6:05 am
I use a 4ft 2x4. It doesn't take long once you get the hang of it.
Jesse
27 PD FPR 16x36 skiff - aka - DITCH WITCH
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu May 30, 2013 6:39 am
If you have alot of prop strikes where you run, its a PITA to take that prop off no matter what you use.
Thu May 30, 2013 8:46 am
^ got that right!
Thu May 30, 2013 8:53 am
Alright I got it off, just needed a 4 ft 2x4. My next question is if anyone has removed that tab of aluminum stock at end of the skeg? I had to bend mine cause it was hitting the new prop.
Thu May 30, 2013 5:47 pm
Mine actually wore off but it won't hurt. Bayouboy makes an awesome skeg if you want to replace it.
Jesse
Thu May 30, 2013 5:59 pm
Users browsing this forum: No registered users and 113 guests
